  3. vbit pattern
  • Subscribers 136
  • Views 9051
vbit pattern
JHC
JHC over 3 years ago
instead of defining a vbit pattern in a ADE library .scs file can the pattern be generated in the ADE schematic or as a parameter which can be modified during simulation?
    ShawnLogan over 3 years ago
    Dear JHC,
    If I understand correctly,  you would like a means to set the pattern as a design variable and then sweep the pattern design variable. If this is correct,  I'm not sure if you tried the methodology outlined at the On-line support site at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nX1CEAU&pageName=ArticleContent
    Shawn
