  3. DC Convergence issues with custom device model
  • Views 12289
sidm
sidm over 3 years ago
I am trying to simulate a circuit with newly developed custom device model but am facing DC convergence issues which I have not been able to resolve with the available online resource on the support website so far.
I am using IC-618 & Spectre-211 (Version 21.1.0.303.isr5 64bit) in ++APS mode in a schematic with just 2 devices a couple of DC voltage sources.
Below are some of the messages from output log so any suggestions on how to diagnose the model specific issues will be very helpful.
Post-Simulation Summary
Analysis Analysis ID CPU (s) Elapsed (s)
1 info checkNPN_asserts 2.01e-03 2.62e-03
2 dc dcOp 2.08e-02 2.14e-02
3 info dcOpInfo 1.55e-03 2.06e-03
4 info modelParameter 1.23e-03 1.70e-03
5 info element 4.15e-03 4.87e-03
6 info outputParameter 1.25e-03 2.09e-03
7 info designParamVals 1.00e-02 1.11e-02
8 info primitives 6.77e-04 1.66e-03
9 info subckts 1.66e-03 2.52e-03
Total 4.33e-02 5.00e-02
Average 4.82e-03 5.56e-03
Elapsed Min info primitives 6.77e-04 1.66e-03
Elapsed Max dc dcOp 2.08e-02 2.14e-02
Opening the PSF file ../psf/dcOp.dc ...
Important parameter values:
reltol = 1e-03
abstol(V) = 1 uV
abstol(I) = 1 pA
temp = 27 C
tnom = 27 C
tempeffects = all
gmindc = 1 pS
rabsshort = 1 mOhm
Bad pivot is found at I26.E_SUM1:bs_p1_bs_p2_flow and I26.N_O
Bad pivot is found at vcath and vcath
Bad pivot is found at I26.E_LAPLACE6:branch and I26.N_O_DELAYED
Trying `homotopy = gmin'.
Bad pivot is found at I26.E_ABM25:bs_p1_bs_p2_flow and I26.MP
Bad pivot is found at I26.E_ABM21:bs_p1_bs_p2_flow and I26.V_BIAS_ON_DEV
Top 2 Solution Convergence failure counts accumulated from the beginning of `dc gmin stepping' analysis
Name: V1:p ( element internal node )
Number of fails: 6. Percent of Fails: 100.00%
----- Elements connected -----
V1
Top 2 Residue Convergence failure counts accumulated from the beginning of `dc gmin stepping' analysis:
Name: I26.E_ABM31:bs_p1_bs_p2_flow ( element internal node )
I26.E_ABM31
Trying `homotopy = source'.
Top 2 Solution Convergence failure counts accumulated from the beginning of `dc source stepping' analysis
Number of fails: 4. Percent of Fails: 50.00%
I26.E_BM11
I26.E_ABM30
Number of fails: 3. Percent of Fails: 37.50%
I26.E_BM11
I26.E_ABM31
Top 2 Residue Convergence failure counts accumulated from the beginning of `dc source stepping' analysis:
Name: I26.E_ABM23:bs_p1_bs_p2_flow ( element internal node )
Number of fails: 7. Percent of Fails: 87.50%
I26.E_ABM23
Error found by spectre during DC analysis `dcOp'.
ERROR (SPECTRE-16385): There were 13 attempts to find the DC solution. In some of those attempts, a signal exceeded the blowup limit of its quantity. The last signal that failed is V(I26.BETA) = -1.15146 GV, for which the quantity is `V' and the blowup limit is (1 GV). It is possible that the circuit has no DC solution. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
ERROR (SPECTRE-16080): Cannot print DC solution because DC did not converge. Resolve the convergence issue and rerun the simulation.
The values for every node on the last Newton iteration are given below. For those nodes that did not converge, the manner in which the convergence criteria were not satisfied is also given.
Failed test: | Value | > RelTol*Ref + AbsTol
Top 10 Solution too large Convergence failure:
V(I26.BETA) = 0 V
update too large: | -767.637 MV | > 0 V + 1 uV
V(I26.P) = 0 V
update too large: | 23.8764 MV | > 0 V + 1 uV
thanks
  • sidm
    thanks
    ShawnLogan over 3 years ago in reply to sidm
    Dear sidm,
    For me anyway, your post really does not provide sufficient information to provide any specific guidance. An input netlist (input.scs) that shows our schematic and the details of your analysis command (i.e.., what analysis options you are choosing) would be helpful. In addition, please include the log file and something more of a description other than "custom model" of your model.
    Obviously, if you are generating your own model, I'm not sure how you verified that a DC solution does exist for the operating conditions of your circuit. If you wanted to verify that it is not the basic circuit in which your models are placed nor the basic simulator, you might consider replacing your custom model with an "ideal" model available from the Cadence library (for example, an nmos or pmos device) and determine if your simulation completes successfully.
    Without more basic information on your simulation setup, model, and results, I, for one, cannot really add any more specific debugging suggestions - sorry sidm!
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    I combined your (sidm's) two posts - one had been stuck in moderation briefly, probably because of the repeated text.
    Anyway, Shawn is right, there's not enough to go on here. The best bet is to contact customer support, but failing that you might get lucky (if somebody has time here to answer) if you can provide the input netlist, any veriloga models (if your "custom model" is Verilog-A) and enough to run the simulation which fails to converge.
  • sidm
    sidm over 3 years ago in reply to Andrew Beckett
    Thanks for the reply and sorry for the double posting as my first post seems was blocked as spam or something hence I created a second one with lesser output log file content.
    I am trying to check if I can share the model file.
    In the meantime can you please let me know if the custom model simulated in Pspice can it still fail when simulating in Spectre ?
    regards
    Andrew Beckett over 3 years ago in reply to sidm
    Yes, this can happen. Without knowing the details though, it's hard to know if that's reasonable or not (sometimes you can find that there may be some heuristics on one simulator or other to deal with poor models that handle them better in one simulator than the other).
