  3. re-use of impulse response models of n-ports
  • Subscribers 136
  • Views 10046
Ali Bastami
Ali Bastami over 3 years ago
Hi
My intention is to speed up my simulations (envlp) by re-use of impulse response models of the n-ports and I was hoping to get some help on how to preceed!
During the envlp sweeps, I see that the first simulation takes about 40 minutes to for spectre to complete (including calculattion/create impulse response bin files) while the following steps in the sweep take no more than couple of minutes (useing the models). But with no changes/updates of the schematic/N-ports/netlist, on the next sweep once again the first simulation takes about 40 minutes and all the bin files are re-generated on the first run.
Is there a way to force specter to re-use the same bin files it created during the very first impulse response calculation for the coming sweeps?
Thanks!
    ShawnLogan over 3 years ago
    Dear Ali Bastami,
    If I understand your question correctly, I think the option to save the impulse response files spectre creates from an S-parameter N-port file already exists and may be selected either through the GUI or through options set in either your .cdsinit file or .cdsenv file.
    A recent document detailing how to set the reuse option and the location of the files in your UNIX directory using the ADE GUI may be found on page 68 of the note st URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009g04cEAA&pageName=ArticleContent
    The location of the impulse response files may be also set within your .cdsenv or .cdsinit files using the "nportirfiledir" option at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tCuTEAU&pageName=ArticleContent
    I hope I understood your question correctly and this provides some help Ali Bastami!
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    Ali,
    in general this should just work - unless something in your environment has turned off the reuse of the impulse response files (and fitting for other interpolation methods). Please contact customer support (you may have done that anyway because as far as I know one of my team is dealing with an impulse response issue from the company you work for; I didn’t check as I’m only on my phone at the moment).
    Rregards,
  • Ali Bastami
    Ali Bastami over 3 years ago in reply to Andrew Beckett
    Thank you ShawnLogan and Andrew.
    I will follow up with customer support!
