  3. Is it possible when schematic changes in virtuso can I get...
  • Views 8042
Is it possible when schematic changes in virtuso can I get some alarm or alert?
shane park
shane park over 3 years ago
Hello.
I want to make skill program that getting some alam (using external script) when schematic changes or user click the 'check and save' button.
It will be better ,if possible, whenever user click the 'check and save' button, run some script.
otherwise, by monitoring some db, I want to run script.
Anyway, Is it possible above action using 'skill language' or other ways?
Thank you
    You could use schRegPreCheckTrigger() or schRegPostCheckTrigger() to ensure a function is called either before or after the "check" part of the check and save.
  • shane park
    shane park over 3 years ago in reply to Andrew Beckett
    I got it.
    Thank you andrew.
