  3. Group as Parametric Set grayed out in Design Variables,...
  • Views 9399
Group as Parametric Set grayed out in Design Variables, but functional in Global Variables
a048
a048 over 3 years ago
Hi, in one particular maestro setup, I'm able to use Group as Parametric Set in Global Variables, but not in Design Variables. What's the issue?
    It's probably explained by this: Why is the 'Group as Parametric Set' option grayed out in maestro view?
  • a048
    a048 over 3 years ago in reply to Andrew Beckett
    I see, thanks, it worked... wasn't able to find anything on google and probably should've tried searching "group as parametric set" at Cadence Support Home and the first link that pops up would be this solution...
    Regards
