  3. Find the Last Wave Transition Delay Time
  • Subscribers 136
  • Views 9583
DramDaddy
DramDaddy over 3 years ago
I'm trying to determine the time between the last edge transition after I set a control signal which based off a timing variable I've placed into the test bench.
I have attempted to use the cross function to achieve this with no good results.
cross(VT("/out") (0.5*VAR("vdd")) 1 "falling" t "VAR("Off")" nil)
Is there another function that can achieve this goal?
Thanks.
    ShawnLogan over 3 years ago
    Dear DramDaddy,
    I apologize, but your objective is not clear to me!
    In Figure 1, I've tried to put together my guess as to your objective with a note about the syntax of your cross() function and a set of outputs to compute what I think you are trying to measure. Of course, you could create a single expression from the illustrated expressions, but I find the use of a number of distinct expressions makes the overall expression more readable and manageable for others viewing your test bench.
    I hope this is something close to what you are intending to measure and it helps provide some thoughts DramDaddy.
    Shawn
    Figure 1
