  3. Is there a way to check edge to edge separation using Assura...
  • Views 8100
Is there a way to check edge to edge separation using Assura 4.16
Florent Jehannin
Florent Jehannin over 3 years ago
I'm trying to flag the distance between two edges using Assura, but I can't seem to find a way to do it.
The sep command only works with polygons and i don't want to apply a grow to the edge because then the distance checked would not be correct.
If anyone has already tried doing this, I would be glad to have your feedback on it.
  • RobMan
    RobMan over 3 years ago +1
    Hi Florent, You could grow the edge shape then apply the drc sep having subtracted 2x the grow distance. Rob.
  • RobMan
    Hi Florent,
    Rob.
  • Florent Jehannin
    Florent Jehannin over 3 years ago in reply to RobMan
    Hi Rob,
    Thanks for your answer.
    That's what I ended up doing after thinking about it again.
    Florent
