  3. problems with pspice model when simulating with spectre
  • Subscribers 136
  • Views 11341
liangqunshan
liangqunshan over 3 years ago
I simulated the IMW120R020M1H and IMW120R045M1 pspice models from  Infenion using the spectre simulator , but encountered the warning (ASL-6246): " Internal (bsource )" 501 : I6.X$M009F.X$M01LF.G01NW : a domain error occured while calculating pow(x,y) for real numbers because a negative value -0.00000 has been specified for x and the value 0.559659 specified for y is not an exact integer .
warning (ASL-6245): " Internal (bsource )" 0 : I6.X$M009F.X01EY.G01PT : a  large value 576.213443 has been specified for the exponential function 'exp()', the value has been clamped to 500  .
warning (ASL-6252): " Internal (bsource )" 0 : I6.X$M009F.X$M01LF.G01NW : a domain error occured while calculating cosh(x) because a large value 3056.610442 has been specified for x . The value has been clamped to 500.
warning (ASL-6254): " Internal (bsource )" 0 : I6.X$M009F.X$M01LF.G01NW : a domain error occured while calculating sinh(x) because a large value 3056.610442 has been specified for x . The value has been clamped to 500.
And many questions like the above.
The I6 is IMW120R020M1H or IMW120R045M1 .
I don't know where the problem is!
How to solve these problems ?
    Two things:
    1. Please give the link where you downloaded the models from - I found these models for the first device at https://www.infineon.com/cms/en/product/power/mosfet/silicon-carbide/discretes/imw120r020m1h/?tab=~%27simulation_models#!designsupport but it does say that these models are for SIMetrixTM-Spice and there's no reference of Pspice.
    2. Please also provide a netlist that shows the problem - knowing how you are instantiating the device and simulating it - how the models are included, the analysis statements etc is pretty important to understand what's going on.
    Even then, this may be beyond what I can do in the forums - it may need more detailed investigation (the models are pretty complex) - so I may end up advising you to contact customer support. You might want to do that anyway instead!
  • liangqunshan
    liangqunshan over 3 years ago in reply to Andrew Beckett
    Hello  Andrew
    I mistook the spice model provided by infenion as the pspice model,This may be the reason why I encountered those problems.
    This is the way I used to call the spice model of Infinion:creat a new cellview---Select pspice in the type column in the 'new file' interface ---Copy spice model code to the text editor(pspice)PSPICE-editor editing  interface---creat---cellview from cellview ---select schematicSymbol in the Tool/Data type column .  After the symbol of the device is generated, it is directly called in the way of ‘creat instance ’ in the Virtuoso Analog Design  Environment L Editing  interface.The following is a schematic I built for testing.
    The following is the relevant netlist:
    If the above method of calling SiC mosfet spice model for simulation is incorrect, then what is the correct method ?
    Regards
    Qunshan Liang
    Andrew Beckett over 3 years ago in reply to liangqunshan
    Qunshan,
    Investigating this wasn't helped by you only having included a screenshot (or rather two screenshots) of the netlist rather than providing it as text. Luckily I could copy and paste the text (by OCR of the images) and then fix a few mistakes where 1's got identified as l's and so on. I was also assuming that you were including the model from Infineon-CoolSiC_silicon_carbide_MOSFET_1200V-SimulationModels-v01_00-EN/Infineon-CoolSiC_silicon_carbide_MOSFET_1200V_SPICE-SimulationModels-v01_03-EN/IMW-IMZA120RXXXM1H_7-40mOhm.lib .
    I don't have your models for mn20v and mp20v, so I just made some simple models up, and with that the simulation runs without any issues in the current Spectre version 21.1.0.716.isr18 . Which Spectre sub-version are you using? (this should show at the top of the log file).
  • liangqunshan
    Hello  Andrew
    I'm sorry to show  the netlist in the way of screenshot, I will pay attention next time.
    I have included the the model of IMW120R020M1H in the netlist ,Just like the last line of netlist:
    pspice_include "/home/qsliang/SiC/SiC_model/IMW120R020M1H_L3/pspice/design.pspice"
    The design.pspice file only contains the code related to the IMW120R020MH model, which was copied from the IMW-IMZA120RXXXM1H_7-40mOhm.lib  file, as follows:
    Note from moderator: removed copyrighted material posted here by the original poster.
    The version of spectre is 15.1.0.257 64bit
    Do I need to install a new version of spectre ?
    Yes. You are using the base release of spectre (then called MMSIM as the release stream) from October 2015 - so almost 8 years ago. Why use something so old? We have a major release of Spectre almost every year (not in 2022, but in every other year).
    Running some tests, I see the messages in the version you're using, but not from Spectre 16.1.0.240.isr2 onwards (SPECTRE161) - released in February 2017. So this has not been an issue for more than 6 years.
    The current version is SPECTRE211 - subversion 21.1.0.716.isr18
    By the way, I edited your post as you had posted Infineon's copyrighted material - since I'd already posted a link to it, I removed it from your post.
  • liangqunshan
    Hi Andrew
    I sincerely appreciate your help !
    I will apply to our manager to install a new version of spectre .
    Thanks again for your help !
    Regards
    Qunshan Liang
