  3. Hierarchical Net Name Preservation in Quantus
  • Views 8145
Anas Wanas
Anas Wanas over 3 years ago
Hi everyone,
We use the qreduce command in Quantus to apply frequency based reduction on an RCC DSPF netlist (generated by a different extraction tool). The options we use for the DSPF netlist change the hierarchical separator from slash to dot as well as preserve the original hierarchical net names so that we have statements such as save Xamp.vs (where vs is a non-port net inside amp subcircuit) work in both schematic and post-layout extractions (can be convenient for testing, even though we know the physical location of vs in the PEX netlist wiggles a bit).
By default, RCC netlists will also generate Xamp.vs, Xamp.vs:1, Xamp.vs:2 , ... , Xamp.vs:99 etc. which are reduced in number by qreduce. The issue is that since qreduce cannot understand that Xamp.vs is a "special" net, it usually removes it, keeping some of the other ":number" nets only (ex. Xamp.vs:76). This breaks the idea of having the hierarchical net names be the same in schematic and layout, so are there any special options or workarounds in qreduce to keep this 'special' net name from being removed?
Theoretically, one can create a script that sweeps over all hierarchical nets in the reduced netlist so that it replaces all instances of the first colon-named net it finds ex. Xamp.vs:76 with Xamp.vs, and repeat for all nets, but I was hoping for a built-in option.
Anas
