  3. adexl does not run neither multicorner nor montecarlo s...
  • Views 7354
adexl does not run neither multicorner nor montecarlo simulations
gnangotzi
gnangotzi over 3 years ago
I heave a recent issue with adexl running multicorner or montecarlo simulation. I am working on IC6.1.8-64b with a TSMC 180nm technology node and the environment has been working perfectly for a long time until recently, since I have installed the TSMC 65nm PDK. When I choose either multiple corners and run "Single Run, Sweeps and Corners) or "Montecarlo sampling", the process is stuck, it does not produce any log file and on the icfb window I have the following message:
*WARNING* Job log file not found; it is likely that the job has not started.
I understand that I'm giving very little information here for debugging, but maybe you can help me to find a way to go through it.
Best
Gian Nicola
