  3. Setting default independent variable in ADE Explorer/As...
  • Views 1638
Setting default independent variable in ADE Explorer/Assembler
CSCNalu
CSCNalu over 3 years ago
Hi
Is there a way to set the default independent variable when you select "Plot All"?  I realize it'll be dependent on each assembler/explorer cellview but is there a way to set the default independent variable for all the graphs?  I know you can set a plotting template but it's a little annoying doing it for large sweeps when you just need a rough idea and you have a ton of data sets and need to reset the "sweep variable" for each of the sub windows.  Minor annoyance but realized I should probably ask.
Thanks!
Chris
    Chris,
    No, because it's dependent upon how the sweeps were structured and whatever measurements you're doing. You could construct expressions using the swapSweep function (these would probably need to be evalType=all or evalType=sweeps/corners depending on what you're doing).
