  3. PVS fails with version `GLIBCXX_3.4.26' not found
  • Subscribers 136
  • Views 4988
thspaet
thspaet over 3 years ago
I'm trying to make PVS (PVS21.12.000-ISR2_lnx86.tgz) work with IC618 (IC06.18.270_lnx86.tgz), but so far I always with this error:
/eda/cadence/2022-2023/lnx86/PVS211/tools.lnx86/pvs/bin/64bit/pvsvirt: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /eda/cadence/2022-2023/lnx86/PVS211/tools.lnx86/pvs/bin/64bit/pvsvirt)
pvsvirt is linked against libstdc++.so.6 but the version, that comes with AlmaLinux8 or rhel8 (i checked them both) only provides up to GLIBCXX_3.4.25. Trying to install the corresponding package from AlmaLinux9 or rhel9 is not an option, because it leads to a dependency nightmare.
As a university chair we receive Cadence through Europractice and it provides two ways to install Cadence.
a) Prepackaged archives that come with a simple script, that simply extracts those archives into a specified folder. Nothing fancy. So far I preferred this way, because it's way easier. But thanks to error I thought maybe someone messed things up during the packaging, so I also tried the other way.
b) The normal way with iscape. But because EP-customers don't have access to the official data sources, there is a small detour by using EP-packed packages again.
Both ways lead to the same error and now I'm out of ideas.
Maybe somebody else ran into a similar problem and can help.
Kind regards,
Thorsten Spätling
  • mschw
    mschw over 3 years ago +1
    Dear Thorsten, have you checked whether your LD_LIBRARY_PATH is set correctly, i.e., that PVS does not load libraries from an incorrect location. I would suggest that you unset LD_LIBRARY_PATH and check…
    Andrew Beckett over 3 years ago in reply to mschw +1
    Thorsten, Can you try running (from a terminal): UNIX> pvsvirt -opt3264 -debugger3264 ldd pvsvirt:---------------------------------------------------------- pvsvirt: INFO: Debugging: "/apps/PVS211…
  • mschw
    Dear Thorsten,
    I would suggest that you unset LD_LIBRARY_PATH and check if that helps.
    Regards
    Matthias
    Thorsten,
    pvsvirt: INFO: Debugging: "/apps/PVS211/21.12.000/tools.lnx86/pvs/bin/64bit/pvsvirt"
    pvsvirt:
    pvsvirt: Once debugger starts up run with:
    pvsvirt:
    pvsvirt: run
    pvsvirt: INFO: Launching debugger: ldd /apps/PVS211/21.12.000/tools.lnx86/pvs/bin/64bit/pvsvirt
    linux-vdso.so.1 => (0x00007ffc1c7a3000)
    libelf.so.1 => /lib64/libelf.so.1 (0x00002b589b2ac000)
    libutil.so.1 => /lib64/libutil.so.1 (0x00002b589b4c4000)
    libnsl.so.1 => /lib64/libnsl.so.1 (0x00002b589b6c7000)
    libstdc++.so.6 => /apps/PVS211/21.12.000/tools.lnx86/lib/64bit/libstdc++.so.6 (0x00002b589b0ad000)
    librt.so.1 => /lib64/librt.so.1 (0x00002b589b8e1000)
    libpthread.so.0 => /lib64/libpthread.so.0 (0x00002b589bae9000)
    libdl.so.2 => /lib64/libdl.so.2 (0x00002b589bd05000)
    libm.so.6 => /lib64/libm.so.6 (0x00002b589bf09000)
    libc.so.6 => /lib64/libc.so.6 (0x00002b589c20b000)
    /lib64/ld-linux-x86-64.so.2 (0x00002b589b088000)
    libgcc_s.so.1 => /apps/PVS211/21.12.000/tools.lnx86/lib/64bit/libgcc_s.so.1 (0x00002b589b288000)
    libz.so.1 => /lib64/libz.so.1 (0x00002b589c5d8000)
    It should be resolving the libstdc++ shared library from the installation itself - can you check to see if that's what you get?
  • thspaet
    thspaet over 3 years ago in reply to Andrew Beckett
    Thank you Matthias and Andrew over the weekend it already dawned on me, that I'm hunting for an error I introduced myself. So when I execute Andrew's command it looks similar and yes, libstdc++ is resolved into the installation folder.
    In hindsight it's totally obvious. When PVS is executed within Cadence, Cadence sets the necessary environmental variables, therefore PVS runs. If I do it on my own those variables aren't set and PVS complains. Makes sense Slight smile
