  3. Importance of "Enable CellView Check" while filling the...
  • Views 1971
Importance of "Enable CellView Check" while filling the quantus assura extraction form?
Vishesh Gupta
Vishesh Gupta over 3 years ago
I am trying to run the assura quantus parasitic extraction with the output selected as extracted view. I encountered with a option in the form called "Enable CellView Check". What is the importance of this option while running the extraction?
Thanks and Regards,
Vishesh
    Vishesh,
    Did you try hitting the "Help" button at the bottom of the form. This takes you to a page (with a lot of detail) but if you search in the doc system for "Enable CellView" you'd have found it says:
    Turning on the Enable CellView Check command causes Quantus to abort if any of the cellViews defined by the extractXXX statements in the LVS rule deck are not found. This occurs regardless of whether the cellViews are actually required in the design. See the Assura Command Reference for more information on the device extraction commands (extractXXX).
    With this command disabled, as a default, Quantus will continue to execute unless a cellView that is actually required by the design is not found.
  • Vishesh Gupta
    Vishesh Gupta over 3 years ago in reply to Andrew Beckett
    Thanks a lot for the reply! This exactly answers my question.
    Vishesh
