  3. Maestro: Simulation Settings as Output Expressions
  • Views 8806
Saikiran IND
Saikiran IND over 3 years ago
I am trying to check if we can somehow print simulation settings such as "reltol", "gmin", "rebuild_matrix" etc as OUPUT expressions in MAESTRO?
I tried VAR("reltol") but it did not work.
Saikiran
    Andrew Beckett over 3 years ago +1
    Not directly, because there's no output database with this information. You could use How to parse Output Log File within ADE Assembler Andrew
  • Saikiran IND
    Saikiran IND over 3 years ago in reply to Andrew Beckett
    Andrew BeckettThis works for my requirement.
    Thanks a lot.
