  3. Title Block cell issue
  • Views 9480
Larry Allen
Larry Allen over 3 years ago
So, I have created a title block cell to place in my schematic views. It lists the following:
LIB: IlInst~>cellView~>libName
CELL: ilInst~>cellView~>cellName
VIEW: ilInst~>cellView~>viewName
Last Saved: ilInst~>cellView~>fileTimeStamp
Last Designer: ilInst~>cellView~>lastDesigner
All of these work except for the Last Designer. Is there a way to have it save who was the last user that saved the schematic view in this title block? I want to be able to see if someone other than the owner has made changes to the vew.
  • Larry Allen
    all of these are of type ILLabel
    Andrew Beckett over 3 years ago in reply to Larry Allen
    Not surprising that lastDesigner doesn't work since it's not something that is normally in the database. You could achieve this with a save trigger which will add the property just before save (this code will add it for schematic, symbol and layout cellViews):
    procedure(CCFlastDesigner(cv)
      unwindProtect(
          dbDisableCellViewCounter(cv)
          cv~>lastDesigner=getLogin()
          dbEnableCellViewCounter(cv)
    dbRegSaveTrigger('CCFlastDesigner)
    The disabling of the counter is just to make sure that this doesn't break check-and-save (otherwise adding the property would make the connectivity seem out of date for netlisting).
  • Larry Allen
    Larry Allen over 3 years ago in reply to Andrew Beckett
    Thanks Andrew. Where would I add this code?
  • Larry Allen
    Larry Allen over 3 years ago in reply to Larry Allen
    just in a .il file and include it from .cdsinit?
  • Larry Allen
    i just put the code in a file and loaded it from my .cdsinit. seems to work. thanks again.
    Yes, that's what I would have suggested.
