  3. ADE Assembler: Get no evaluation for DC sensitivity ana...
  • Views 10016
ADE Assembler: Get no evaluation for DC sensitivity analysis
StephanWeber
StephanWeber over 3 years ago
I made an Assembler test settup, which include a sens analysis (for dcOP and dc). I define outputs (like not voltage at net Out) and to which elements I need the sensitivity (like V1). I can run this, and using the Results Browser I can get all results (like send to Table or Plot).
However, I I do send to Calculator, it does not work anymore, also sending this to ADE output setup.
I wonder what is going wrong:
Here is setup:
Sim:
dcOp dc write="spectre.dc" save=allpub maxiters=150 maxsteps=10000 \
    annotate=status
dcOpInfo info what=oppoint where=rawfile
dc dc param=Iin start=0 stop=2 lin=20 values=[1m 5m 10m 20m] save=allpub \
    oppoint=rawfile maxiters=150 maxsteps=10000 annotate=status
sens (OutDM OutCM ) to (V1 V2 I22 V8 I13 ) for (dcOp dc )
Outputs:
getData("/sens1:OutCM,I13:dc" ?result "dcOpSens")
getData("/sens1:OutCM,I13:dc" ?result "dcSens")
I wonder about sens1, but also modifying it in the Calculator to sens does not help.
Error message example:
ERROR (VIVA-3002):expression evaluation failed: getData("/sens1:OutCM,I13:dc" ?result "dcOpSens")
ERROR (VIVA-3002):expression evaluation failed: Expression evaluates to nil
ERROR (VIVA-3002):expression evaluation failed: getData("/sens1:OutCM,I13:freq" ?result "dcSens")
Bye Stephan
  • StephanWeber
    Little addition:
    I have two dc analysis active this is the reason for getting sens1. However, removing one dc analysis does not help: I get now "sens" in Send to Calculator, but still it does not work, outside Results Browser.
  • StephanWeber
    StephanWeber over 3 years ago in reply to StephanWeber
    I am using Virtuoso 20.1.500 isr31. I tried using the calculator directly, but e.g. geta data leads me only to a text window. This contains the sens analysis, but no further data.
    Andrew Beckett over 3 years ago in reply to StephanWeber
    Stephan,
    The issue is that it is mistakenly mapping the name back to a schematic name. Of course, there is no instance in the design called /sens1:OutCM,I13:dc and so it goes wrong.
    You can do two things:
    1. Omit the initial slash to use netlist names: getData("sens1:OutCM,I13:dc" ?result "dcSens")
    2. Use pv() instead - in that case it works with or without the initial slash: pv("/sens1" "OutCM,I13:dc" ?result "dcSens")
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    Thanks Andrew. I removed the / and it works fine now!
