  3. Ramp signal generator in Verilog-A
  • Subscribers 136
  • Views 12160
delgsy
delgsy over 3 years ago
I need a ramp signal that starts ramping (e.g., from 500mV to 800mV in 100ns) at the falling edge of the control signal.
Here is the snipet which gives something close to what I need but I do not like the way I wrote it, i.e., 100ns is used in the argument for transition().
The result also shows 800mV at the beginning which I do not understand why.
Maybe there is a more proper way to realize this.
the control signal in this example is NREAD_TOA.
    //RAMP
    @(cross(V(NREAD_TOA) - V(VDDA_P1V2)/2, -1))
    begin
    RAMP_START_TON = $abstime;
    RAMP_START_TOFF = RAMP_START_TON + 1n; // I do not like this because I think this is not a proper way.
    end
    @(timer(RAMP_START_TON))
    RAMP_VHIGH = 500m;
    @(timer(RAMP_START_TOFF))
    RAMP_VHIGH = 800m;
    V(RAMP_START) <+ transition(RAMP_VHIGH, TDELAY, 100n, TFALL); // I do not like this because I think this is not a proper way.
    ShawnLogan over 3 years ago +1
    Dear delgsy, delgsy said: but I do not like the way I wrote it, i.e., 100ns is used in the argument for transition(). The result also shows 800mV at the beginning which I do not understand why. Maybe…
    Dear delgsy,
    If you are interested, a couple of comments that come to mind...
    1. In general, a more common means of creating a ramp generator is to use the integration function idt(). In this fashion, you can set the slope of the ramp in lieu of using the rise time parameter of the transition filter. Hence, if you use a statement similar to:
      V(out) <+  idt(slope*1.0,ramp_init)
    and specify the value of slope as (0.80 - 0.50)/100e-09, after 100 ns it will set out to 0.80 V from an initial value of 0.50 V. You will need a second event (timer or conditional statement to monitor value of V(out)) to stop the integration when its value reaches your desired maximum value of 0.80 V.
    2. With respect to your observation that your code produces an 800 mV output value at the start of your simulation, I noted you did not include an initial_step event in your snippet. Perhaps you included it outside of your posted code? An initial_step event is executed only on the first point of the analysis and is commonly used to initialize signals and variables.
    real ramp_init = 0.50;
    analog begin
      @(initial_step) begin
       ramp = ramp_init ;
    end
    Shawn
