  3. rexMatchp error when netlist
  • Views 8599
sjwprcker
sjwprcker over 3 years ago
I got the error in CIW when netlsit is created from maestro
*Error* rexMatchp: argument #2 should be either a string or a symbol (type template = "tS") - nil
This error will not block my simulation, but appears everytime netlist is created.
I use ams simulatior in my test bench.
My cadence version is ICADVM20.1-64b.500.30, MMSIM version is 21.1.0.664.isr16, Xcelium version is 22.03-s001.
If anyone has clue about this error?
Thanks for your attention.
BR
    This is probably best handled through customer support, and I'm guessing it might be PDK-related, but perhaps you could enter this in the CIW:
    _stacktrace=50
    tracelength=tracelevel=50
    sstatus(errsetTrace t)
    and then do Simulation→Netlist→Recreate and then share any output you get - this might give a clue as to where it is failing?
