  3. Maestro : Width of columns in "Results" Tab is large. How...
  • Views 2193
Maestro : Width of columns in "Results" Tab is large. How to reduce it?
Saikiran IND
Saikiran IND over 3 years ago
Hello ,
For me, the width in the results tab is very big and I need to reduce it every time I run a test. The attached image would give more insight into the issue. Any idea how to adjust it or where do I find setting for that?
Saikiran
    Andrew Beckett over 3 years ago +2
    Saikiran, There is an existing change request (CCR 1006667) with a lot of duplicates from other customers asking for control over the column widths or auto-resizing; it hasn't been implemented yet. …
    Saikiran,
    • Vote Up +2 Vote Down
  • Saikiran IND
    Saikiran IND over 3 years ago in reply to Andrew Beckett
    Noted Andrew Beckett. Thank you
