  3. NO DC solution found(No convergence) when use ADEXL,but...
  • Views 2860
NO DC solution found(No convergence) when use ADEXL,but use ADEL is right.
SpiceHusky
SpiceHusky over 3 years ago
I simulate a buf with multiple feedback loops. When I use ADEXL simulate corners, many corner displays sim errors. The output log displays  NO DC solution found(No convergence). But I use ADEL to simulate the same corner, the result is successful.May I ask how to solve this problem?
    There must be a difference, because ultimately Spectre runs on a netlist. I'd start by comparing the netlists to determine what is different.
  • SpiceHusky
    SpiceHusky over 3 years ago in reply to Andrew Beckett
    I checked and found that the two netlists are the same.
    Andrew Beckett over 3 years ago in reply to SpiceHusky
    OK, the next thing to check was whether they were simulated with the same options. Check the command-line at the top of the spectre log file - was one run with APS and one without, for example?
    There must be a difference in either the netlist or the command-line arguments to the simulator - otherwise the simulator is seeing the same thing. There have been very rare cases where there is some random initialisation problem, but that's extremely unlikely.
    If you can't find a difference, please contact customer support.
