  3. Noise Summary per Instance
  • Subscribers 136
  • Views 11659
Ali Nikoofard
Ali Nikoofard over 3 years ago
I am looking at this thread but cannot understand how to get the same results for my case. Noise contribution of an instance - Custom IC Design - Cadence Technology Forums - Cadence Community
Using ADE Assembler running noise sim selecting output nodes and input port, obviously I want to get per instance noise contribution, is there a simple way maybe to explain what Andrew said in previous thread? Maybe even a script that spits the noise from all instances at top?
Spectre version 21.1.0 64bit
virtuoso version 6.1.8-64b
    ShawnLogan over 3 years ago
    Dear illaoi,
    If I understand your question correctly, I believe your need may be satisfied by invoking the ocean command noiseSummary() . You mentioned you are using Assembler, and there happens to be a Troubleshooting article at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXTZEA2&pageName=ArticleContent
    that outlines how to write the output of the noiseSummary(0 command to a file using an ocean script following one or more Assembler corners within a test. There are many options to the noiseSummary() command that are outlined in the ocean manual at URL:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=oceanref.xml&title=OCEAN%20Reference%20--%20Plotting%20and%20Printing%20Commands%20-%20noiseSummary&hash=pgfId-1022929&c_version=ICADVM20.1&path=oceanref/oceanrefICADVM20.1/chap8.html#pgfId-1022929
    Finally, if you might be interested in some additional Troubleshooting articles detailing methods to sort the outputs of the command and separate noise types (flicker/thermal) at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVoGEAU&pageName=ArticleContent
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000007MY0rEAG&pageName=ArticleContent
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tlwYEAQ&pageName=ArticleContent
    support.cadence.com/.../ArticleAttachmentPortal
    I hope I understood your question and these provide some ideas illaoi!
    Shawn
  • Ali Nikoofard
    Ali Nikoofard over 3 years ago in reply to ShawnLogan
    Thanks Shawn, I cannot access the links (not CAD manager), is there a way to suggest a simplified solution in the thread?
    ShawnLogan over 3 years ago in reply to Ali Nikoofard
    Dear illaoi,
    You do not need to be a CAD manager to access On-line support. All you need to do is request the information you are prompted for when you attempt to login. You will see a GUI similar to what I show below and ask your CAD manager for the appropriate information to create your on-line support account. I would seriously consider getting an account as there is a wealth of valuable information I know you will find helpful illaoi.
    As you probably know, I am not allowed to simply copy On-line support information to a Forum post. At the bottom of the most relevant URL I provided, it states:
    Caution: All content on this site is Cadence Confidential and for Cadence customers only. DO NOT DISTRIBUTE.
    I am very sorry!
    Perhaps if the Forum moderator reads this, he or she might permit me to provide the information, but in the interim, I feel I must respect Cadence's policy.
    Shawn
  • Ali Nikoofard
    Shawn,
    I was able to figure something out but I am seeing unexpected results, so in maestro we can directly open a terminal, which would be in the interactive.xyz, then I would cd till I get to the folder that I see netlist and psf folder.
    in the psf folder there is a file called noise.noise. In the folder that its name end with test name I type
    noisesummary psf/ noise-noise /I36
    /I36 is the instance at the top, then inside psf, I see noisesummary.psf and using what Andrew said, I can convert to ascii and read, though when I change instances, I see the same amount of total noise.
    Is me writing /I36 is incorrect, even if I want I6 in I36, wouldn't I do /I36/I6 and should see much smaller total noise?
    HEADER
    "PSFversion" "1.00"
    "BINPSF creation time" "1684948054"
    "simulator" "Spectre"
    "date" "Wed May 24 10:39:43 2023"
    TYPE
    "sweep" FLOAT DOUBLE PROP(
    "key" "sweep"
    "V/sqrt(Hz)" FLOAT DOUBLE PROP(
    "units" "V/sqrt(Hz)"
    "key" "noise"
    "V/V" FLOAT DOUBLE PROP(
    "units" "V/V"
    "key" "noise"
    SWEEP
    "freq" "sweep" PROP(
    "sweep_direction" 0
    "units" "Hz"
    "plot" 0
    "grid" 1
    TRACE
    "TOTAL" "V/sqrt(Hz)"
    "gain" "V/V"
    VALUE
    "freq" 2.00000e+09
    "TOTAL" 5.63500e-18
    "gain" 2.95113
    "freq" 3.00000e+09
    "TOTAL" 7.51267e-18
    "gain" 3.82142
    "freq" 4.00000e+09
    "TOTAL" 1.10199e-17
    "gain" 4.75098
    "freq" 5.00000e+09
    "TOTAL" 1.44997e-17
    "gain" 5.02888
    END
    Andrew Beckett over 3 years ago in reply to Ali Nikoofard
    Actually, the best article on this is probably this: How do I Create a Noise Summary Automatically in ADE Explorer/Assembler because it uses the ocnGenNoiseSummary function to generate the noise for a particular hierarchy depth. Examples are shown with how to retrieve the noise from a particular hierarchical block.
    Your usage of the noisesummary command is incorrect; the third command-line argument is not the instance name (and certainly not the hierarchical schematic name (it might have been the netlist name, but it's not even that)). It's supposed to be the hierarchy depth as a number.
    I suggest you get support.cadence.com access and look at the article I linked to. Put simply though, you could add an output:
    ocnGenNoiseSummary(2 ?result 'noise) && getData("I0.I3:total" ?result "noisesummary"))
    Something like that. You could also look at the documentation for ocnGenNoiseSummary.
