  3. ADE Reliability analysis: Also for XF and DCMatch?
  • Subscribers 129
  • Views 6507
StephanWeber
StephanWeber over 2 years ago
To get all PSRR's I am using all the times XF instead of AC analysis, but now I see in rel analysis xf (and few others) are not supported.
Is there a workaround to run also XF?
Virtuoso 20.1 is used,
Bye Stephan
    Hi Stephan
    XF analysis is supported for reliability analysis since SPECTRE21.1 ISR18 and in ADE it will be supported (together with that spectre version) in ICADVM20.1/IC6.1.8 ISR33 (ISR32 is the current version, with ISR33 due to be available around the 21st July 2023). If you need it more urgently, maybe an engineering hotfix or a patch could be generated but you'll have to request this via customer support (you'd still need to use that version of Spectre).
  • StephanWeber
    StephanWeber over 2 years ago in reply to Andrew Beckett
    Many thanks! Will talk with our CAD team to enable this.
    Bye Stephan
