  3. environment variable to enable LSCS
  • Subscribers 137
  • Views 10360
sjwprcker
sjwprcker over 3 years ago
I would like to ensure the default job mode is LSCS, but NOT ICRP.
How can define this by environment variable?
My cds version is ICADVM20.1-64b.500.30
My spectre version is 21.1.0.664.isr16.
Thanks for your help!
  • mschw
    mschw over 3 years ago
    This article explains how to do it.
    Matthias
  • sjwprcker
    sjwprcker over 3 years ago in reply to mschw
    Hi Matthias,
    Thanks a lot for your reply, which works well!
    Do you know any environment variable can set the job policy (suppose I have several customized jobpolicies) in case of LSCS?
    BR
    ShawnLogan over 3 years ago in reply to sjwprcker
    Dear sjwprcker,
    A quick search on the On-line support site provides the following commands to set the default job policy in LSCS job control mode. Hopefully, I understood your intent sjwprcker!
    Shawn
    .cdsenv:
    maestro.lscs  defaultSimulationJobPolicy string "mySimuJobPolicy"
    .cdsinit:
    envSetVal("maestro.lscs" "defaultSimulationJobPolicy" 'string "mySimuJobPolicy")
    where mySimuJobPolicy is the name of your job policy.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009MpcyUAC&pageName=ArticleContent
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    There is also:
    maestro.lscs     defaultNetlistingJobPolicy string "myNetlistPolicy"
    or
    envSetVal("maestro.lscs" "defaultNetlistingJobPolicy" 'string "myNetlistPolicy")
    for the other half of what's needed for LSCS.
  • sjwprcker
    sjwprcker over 3 years ago in reply to Andrew Beckett
    Hi ShawnLogan and Andrew, your solution works perfectly.
    Thanks a lot!
