  3. how to simulate spatial variation to see benefit of common...
  • Views 8532
how to simulate spatial variation to see benefit of common centroid layout
supriyo1985
supriyo1985 over 3 years ago
Is it possible to run post-layout simulation with spatial variation (Monte Carlo) in virtuoso to see the benefit of common centroid layout?
    No, because this is not how Monte Carlo simulation works.
    • Monte Carlo "mismatch" in Spectre isn't modelling mismatch due to placement. Instead it is actually modelling the residual local variation (device to device) rather than die to die "global" variation (called "process" in Spectre's terminology)
    • The models you get from foundries have no sensitivity to distance between devices. They don't characterise that.
    • Even if they did, there's nothing to describe the distance or alignment of devices and feed that into the simulation.
  • supriyo1985
    supriyo1985 over 3 years ago in reply to Andrew Beckett
    Thanks.
