  3. Netlist fails due to missing "nlAction" value
  • Replies 8
  • Subscribers 139
  • Views 6807
HoWei
HoWei over 3 years ago
We receive IP packages (OA-libs) from partners in which the instances do have the user-property "nlAction" without any value given.
This results in netlisting-errors, because "nlAction" requires the value "stop" or "ignore".
Currently the only option I see is to edit all instances in the hierarchy manually and save the IP cells again. But of course this is a bad way, because we do not want to touch the delivered IPs.
What are the options to fix this without editing all the instance-parameters manually ?
Can I set a global parameter for "lnAction" which is used by those instances ?
    Andrew Beckett over 3 years ago in reply to sbrenna +1
    sbrenna said: can a global parameter , a global variable or a local variable be used to pass the value of nlAction property to each different block? No.
    First of all, I'd request that the IP vendors do not do this - you should get them to fix it as part of their delivery.
    I'm not aware of any controls to override this - but maybe it would help because you're only wanting to override the error when it fails without a value given - I'd need to know exactly how it's failing to see whether that's a possibility:
    1. Which netlister are you talking about?
    2. What exactly is the error message given
    These two pieces of information will help track down exactly where this is happening to see whether there is a possibility of overriding the behaviour; there are lots of checks for nlAction throughout the code, but probably only very few places where it doesn't explicitly look for stop or ignore.
  • HoWei
    HoWei over 3 years ago in reply to Andrew Beckett
    I am using ICADVM20.1 with simulator=AMS (Spectre / XCELIUM).
    The error shows up in the CIW window directly after starting the simulation - this is when Xcelium is not yet started:
    Currently it is only a handfull of instances which I needed to modify - this solved my issue for now, but if its a huge number of instances affected, then a general automated solution would be helpful.
    Andrew Beckett over 3 years ago in reply to HoWei
    I checked in the code, and there's no way of suppressing that error. To be honest, the source data is just wrong - it should be corrected, as I said before. How did they netlist it in the first place? (maybe it originated from some non-Cadence tool).
  • HoWei
    Yes, you are right - the partner is using a Synopsys tool-flow for those IP developments.
    Thanks for the investigations - I will try to get the issue fixed on the supplier/partners side.
  • monglebest2022
    monglebest2022 over 3 years ago
    I encounter a similar issue with AMS simulator recently. I need this nlaction there because I have this cell instantiated somewhere else with nlaction=ignore. It looks like to me, the simulation with both spectre or AMS goes fine without a cadence upgrade. It looks like the simulator now force to check this parameter set or not. It's a good thing but there should be a parameter for the AMS to disable this check (since now it's forced to check) otherwise there are huge amount of maintenance issue in legacy library.
    BTW, I also find this thread earlier, https://designers-guide.org/forum/YaBB.pl?action=print;num=1447429351, but it looks like I should put nlaction=stop based on the cadence help doc.
    Andrew Beckett over 3 years ago in reply to monglebest2022
    I'm pretty certain having nlAction with no recognised value has never been supported (my reply on that other post was from 8 years ago, and it was the same then). Are you saying that you have nlAction=ignore on the spectre view or symbol view somewhere and you then need to override that on a specific instance? That's a reasonable justification for having an "allowed" value, but it's a pretty rare scenario. It's not obvious to me whether setting nlAction=stop is the right thing to do or not (It depends on whether it really is a stopping view).
    I suggest you contact customer support so that the specifics of what you need can be discussed and then an enhancement filed if required. I had been wondering whether using nlIgnore instead would help, but I don't think that does (I don't know your specific requirement, but I think having nlIgnore set to ignore for a particular simulator on the master or switch view will supersede any instance setting - I didn't test this).
  • sbrenna
    sbrenna over 3 years ago in reply to Andrew Beckett
    I have the same question posed by the author of this thread:
    Stefano
    No.
