  3. PDK patch installation through 'virtuoso -nograph' requiring...
  • Views 6351
PDK patch installation through 'virtuoso -nograph' requiring Xvfb is not working on RHEL 8.x
Johan Van der Borght
Johan Van der Borght over 3 years ago
In the posts Xvfb has replaced cdsXvnc as the -nograph display server and The New Virtuoso nograph Server Xvfb was made default it turns out that Xvfb is the new 'virtuoso -nograph' environment.
However, in RHEL 8.x, Xvfb is not supported by default, and installation may even break the regular Xserver software.
We need to install a PDK patch script, which uses the -nograph option of virtuoso.
The installed version is ISR32, so should be okay, but all we get is:
PDK patch installing ...
cdsXvfb-run[3027647]: ERROR: /usr/bin/Xvfb is missing: checkSysConf should be run and the missing RPM installed.
cdsXvfb-run[3027647]: ERROR: Aborting.
checkSysConfig returns:
============== checkSysConf: Version 3.51 ====================
Configuration checks failed on this workstation (seabert.soficsbv), status is: FAIL
This operating system version '8.0WS' is not supported
If you believe you are running a supported OS then check that
the OS version directory exists in the data directory:
/opt/cadence/current/share/patchData/Linux/x86_64
Exiting checkSysConf ... Good-bye
So it says that RHEL8.x is still not supported...
Thus: installing a patch returns the issue that we have to run the 'checkSysConfig' tool, which in turn says that the OS (RHEL 8.6) is not supported.
The correct RPM (which is thus not stated, but we believe is xorg-x11-server-Xvfb) does NOT exist.
Can you explain how we should proceed?
  • Johan Van der Borght
    Johan Van der Borght over 3 years ago in reply to Andrew Beckett +1
    It might be that we've found the solution after all: the package is not in the default RHEL8 distribution, but... you can also enable additional optional repos!!! the repos are: - codeready-builder…
    There's no checkSysConf data for IC6.1.8/ICADVM20.1 for RHEL8 because it is not officially supported (this means that it was not in the platform matrix when first released in 2018, and is not routinely tested). However, some changes were made in ISR24 to allow it to run, but as it's not routinely tested there are still no patch data files.
    The checkSysConf data for the upcoming Virtuoso Studio (IC23.1) which comes out at the end of June does contain a requirement to install at least xorg-x11-server-Xvfb-1.20.3 on RHEL8 (there are patch data files for this release because IC23.1 does indeed support RHEL8). That should exist (I can certainly find it with a spot of google searching).
    Unfortunately, it seems that you have another google engine than I do: no valid RHEL8 RPM's are available.
    You can find plenty of Xvfb RPM's, but none is qualified for RHEL8
    (https://pkgs.org/download/xorg-x11-server-Xvfb ; https://rpmfind.net/linux/rpm2html/search.php?query=xorg-x11-Xvfb&submit=Search+...&system=&arch= ; https://rpm.pbone.net/ )
    All for RHEL7, never for RHEL8.
    Besides, what's the risk of screwing the existing X11 environment (We use X11 for VNC and for X forwarding like through PuTTY)?
    Andrew Beckett over 3 years ago in reply to Johan Van der Borght
    My google search for "xorg-x11-server-Xvfb RHEL8" found this: https://centos.pkgs.org/8-stream/centos-appstream-x86_64/xorg-x11-server-Xvfb-1.20.10-1.el8.x86_64.rpm.html (yes, it's the CentOS link, but I'd expect RHEL8 RPMs to come from RedHat via a subscription; I can't check that because I don't have access myself as this is handled centrally within Cadence). I just checked on a RHEL8.4 machine that ended up on in our compute farm and that has it installed. I can't confirm from where it was downloaded (without asking our IT - sorry, I've been out of the office today), but I'd be a little surprised if it was from CentOS since it's a RHEL8.4 image.
    I'm not aware of any issue with this affecting existing X11 environments. Given the contents, it seems highly unlikely - here's the contents of the rpm on the machine I looked at:
    UNIX> rpm -ql xorg-x11-server-Xvfb-1.20.10-1.el8.x86_64
    /usr/bin/Xvfb
    /usr/bin/xvfb-run
    /usr/lib/.build-id
    /usr/lib/.build-id/0a
    /usr/lib/.build-id/0a/7eaea725408107f868c885bca522b1d52a98c0
    /usr/share/man/man1/Xvfb.1.gz
    This is consistent with the contents listed on the link I showed above. In other words, there are two executables and a man page - I can't see how this could possibly interfere with anything else.
    BTW, your post went into moderation not because there was any concern about what you were saying; it was the presence of an external URL that triggers the 'potential spam'  check which puts it into moderation. Whilst that's obviously inconvenient for you, it's far less annoying that the high volume of link-spam we used to frequently get on the forums. Sorry for the inconvenience and delay until I could approve the post.
    the repos are:
    - codeready-builder-for-rhel-8-x86_64-rpms
    - rhel-8-for-x86_64-supplementary-rpms
    To enable, you need to add these additional repos to your repo-browser as superuser with:
    subscription-manager repos --enable <repo-name>
    And then you can run
    yum install xorg-x11-server-Xvfb
