  3. How to use value function in calc with multiple interpolation...
  • Views 8736
How to use value function in calc with multiple interpolation time that is not periodic?
delgsy
delgsy over 3 years ago
I want to know the values of green signal when the red signal goes low.
Using cross function, I am able to generate a list of time stamp (yellow) that shows when the red signal goes down.
I put this cross expression in the "Interpolate at" field of value function.
But value function in calc requires the value of period without which it will show error.
    Andrew Beckett over 3 years ago +1
    I think this is probably what you want: Calculator function to measure the value of a waveform when another waveform crosses a threshold Andrew
