  3. A2D Bus value for MC analysis
  • Views 8236
KhanAmir
KhanAmir over 3 years ago
I want to use the value generated by the digital bus in the MC simulation. I have seen This post and I am able to generate the bus value. But when I put this expression in the ADE and re-simulate it, it does not give me the value. How to do it? My version of cadence is IC6.1.7.
    There are a lot of suggestions in that post, so it would rather help if you gave the actual expression you're using. Is this a spectre or AMS simulation? A few more details would help...
  • KhanAmir
    KhanAmir over 3 years ago in reply to Andrew Beckett
    Thanks for your prompt response. I am using Spectre. The output is from a counter (10 bit). I converted the analog bus to digital and then calculated value.
    numConv(value(awvCreateBus("Count" list(awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre") awvAnalog2Digital(VT("/Count<0:9>") nil nil 0.6 nil "centre")) "Signed Decimal") 0.000102 ?extrapolate nil) "dec" t)
    if any other information is needed kindly let me know.
  • KhanAmir
    KhanAmir over 3 years ago in reply to KhanAmir
    Hi, any suggestions?
