  3. Q of a tank circuit
  • Subscribers 136
  • Views 7720
Q of a tank circuit
Sumit Dash
Sumit Dash over 3 years ago
 I am trying to find the Q of a series resonance circuit. To do so, I plotted the Y parameter of the tank. I got the resonance frequency from the plot. However, when I am using the cross-function to get the 3dB bandwidth of the tank, it is showing some error messages.
Cross Function to get the 3 dB bandwidth in series tank :  cross( db(ypm('sp 1 1))  ymax(db(ypm('sp 1 1))) - 3 1 "either" t "cycle" nil).
Error message: too many arguments (at most 7 expected, 8 given).
Is there any other way of doing the same?
    ShawnLogan over 3 years ago
    Dear Sumit Dash,
    For a frequency domain signal, a more appropriate function to use to compute the 3 dB bandwidth of a signal is the bandwidth() ViVA or ocean function. In your case, since you are essentially interested in the 3 dB bandwidth of what appears to be a "bandpass" response, the type argument of the function should be set to "band". In your case, I think the appropriate expression may be:
    bandwidth( db(ypm('sp 1 1) 3 "band")
    Shawn
