  3. How to use the same Plotting Template from different Maestro...
  • Subscribers 136
  • Views 6763
How to use the same Plotting Template from different Maestro file?
delgsy
delgsy over 3 years ago
I have created a plotting template and been using it from the first maestro, let's call it maestro-A.
Then I made a copy of maestro-A into maestro-B.
After running a test from maestro-B, which is available also in maestro-A, I would like to use the plotting template.
But it seems that the plotting template does not work.
Or do I need to create a new Plotting Template every time I created a new maestro?
