  3. Syntax in ADE output expression for finding the minimum...
  • Subscribers 136
  • Views 12046
Syntax in ADE output expression for finding the minimum of two or more numbers
yxie
yxie over 3 years ago
Product: IC6.1.8
An output "A" is defined and its value is returned (i.e., updated, refreshed) per Spectre simulation run. Then I want to define another output "B", whose value is the smallest of output "A" and "0.5" (for example). How do I construct the output expression for "B"? I was thinking something like B = min(A, 0.5).
I've tried Calculator function "ymin" like this B = ymin(A 0.5), but for ymin, the syntax of A 0.5 is wrong, apparently, my sense is that A 0.5 has to form a vector, but how? I don't know. I've tried [A 0.5], or {A 0.5}, i.e., B = ymin([A 0.5]), that didn't work. When I searched Cadence knowledge base, I found this article but it leads to nowhere.
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/23964/about-selecting-the-minimum-value-among-two-or-more
Would someone please help?
    ShawnLogan over 3 years ago
    Dear yxie,
    Have you considered using a conditional expression to define your variable B? For example:
    B is a new design variable dependent on the value of A. Hence define variable B as:
    if( (VAL("A") < 0.5) then VAL("A") else 0.5)
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    yxie, sadly Shawn's answer won't work because a) you're talking about an output expression, and b) he uses a function VAL() that doesn't exist (I assume he meant VAR()).
    Anyway, the way to do this would indeed to be have an output with an expression min(A 0.5) - the min function does support waveform objects as well as numbers, so this should work fine (at least it does in current versions; I just tested it; I'm not sure which IC sub-version you're using since you didn't say).
  • yxie
    yxie over 3 years ago in reply to Andrew Beckett
    Yeah, thanks, Andrew, it works with this subversion I am now working with IC6.1.8-64b.500.25. Also, thank Shawn - yes, I did try that as well; somehow the subversion I was working with then didn't seem to work. Anyhow, the min/max function allows me set the upper and lower limit to a trim code which also a design variable, that based on a measurement on simulation result of previous run.
