  3. verilog-a syntax to read a 64-bit binary value from a f...
  • Subscribers 136
  • Views 9637
verilog-a syntax to read a 64-bit binary value from a file
MikeVP
MikeVP over 3 years ago
I have a text file with this format:
1511874.802,0000000000000000000000000000000000000000000000000000000000000000
1512541.468,0000000000000001000000100000001100000100000001010000011000000111
1513208.134,0000100000001001000010100000101100001100000011010000111000001111
I want to read the 64-bit binary value, and then use a genvar to set an output vector, like this:
 for(i=0;i<64;i=i+1)
V(txdata[i]) <+ transition( binVal & (1<<i)?voh:vol, 0, 10n, 10n );
Using this to read the file:
$fscanf( file, "%f,%b", timeVal, binVal );
Here is where I am stuck.  What data type do I use for binVal?  I cannot read the binary value into an integer, since that is only 32 bits.  Reading it as a string or real will work, but it is not obvious how I convert a real/string back to an integer.
Using a real returns a very small number, like 1e-316, since the MSB is a 0.
Is it possible to read it as a string, then do a character comparison?
Any ideas?
  • GeoffreyC
    GeoffreyC over 3 years ago
    Yes, I think reading it in as a string would work; you can use .substr(i,i) to get the ith bit.
  • MikeVP
    MikeVP over 3 years ago in reply to GeoffreyC
    Thank you very much, that works great.  I've now bookmarked the Cadence Verilog-A manual instead of using what comes up on Google.
