  3. Difference between a power and signal pin?
  • Views 9015
Vishesh Gupta
Vishesh Gupta over 3 years ago
I am making a schematic on virtuoso.
What difference will it make if I use a signal pin instead of a power pin for VDD (when choosing the signal type for the pin)?
Thanks and regards,
Vishesh
  • Vishesh Gupta
    Please tell if I have not given information for understanding of the above question.
    I really appreciate your time for reading the question.
    Andrew Beckett over 3 years ago in reply to Vishesh Gupta
    In manual flows, it typically doesn't matter. It is more important for place and route flows (e.g. if you're using the Virtuoso Space-Based Router, or using LEF/DEF or Innovus flows) as typically these have specialised routers for power/ground and (for example) clocks. The signal type is typically used to identify such special types of nets in those flows.
  • Vishesh Gupta
    Vishesh Gupta over 3 years ago in reply to Andrew Beckett
    Thanks a lot for the reply. It answer my question.
    Vishesh
