  3. Using Spectre MDL to optimize transistor multiplicity (integer...
  • Subscribers 138
  • Views 9801
Using Spectre MDL to optimize transistor multiplicity (integer parameters)
ConradJ
ConradJ over 3 years ago
Hello!
I am trying to use MDL's built in `mvarsearch` to optimize a buffer to reduce the difference between input and output waveform. The problem is `mvarsearch` is treating transistor multiplicity parameters like a real number, not an integer.
Is it possible to specify an optimization parameter as an integer or achieve a similar effect?
Thank you!
    Andrew Beckett over 3 years ago in reply to Andrew Beckett +1
    ConradJ I spent a bit of time trying to get this working. First of all I found that making a spectre parameter an integer seemed to prevent it getting passed to the netlist, so instead I tried this: …
    ShawnLogan over 3 years ago
    Dear ConradJ,
    I am neither an SDL expert nor a regular MDL user, but the thought that came to mind as I don't know of a way to force the optimizer to perform an integer search, is to utilize a couple of foreach loops for sets of integer values that are realistic.
    For example, suppose  the variable M_nmos is the nmos multiplier and M_pmos is the pmos multiplier. Suppose you expect the multiplier values to be between 5 and 10 for M_nmos and 10 and 20 for M_pmos. You may have other parameters that are varying (such as channel length for example) in the optimization. You might consider the following basic syntax:
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    Not sure how Shawn's suggestion is going to work since that just adds two loops around the search - and so will just do 66 optimisations, rather than one optimisation to find the two M factors.
    I think it should work (based on a previous change request) by simply declaring the parameter in the MDL file (above the mvarsearch) as an integer:
    int M_nmos=5
    int M_pmos=10
    (you have to declare an initial value when declaring it).
    I've not got a decent test case to try this out on to hand. If I have a moment, I'll do so later today.
    ConradJI spent a bit of time trying to get this working. First of all I found that making a spectre parameter an integer seemed to prevent it getting passed to the netlist, so instead I tried this:
    //  mvar.mdl
    //  (C) 2008 Cadence Design Systems, Inc.
    // This example is to find optimal values of design parameters
    // by running a multi-parameter, multi-goal search function
    // alias measurement definition
    alias measurement trans {
      // definition of transient analysis with autostop turned on
      run tran( stop=1u, autostop='yes )
         // computation of risetime for signal V(out) from 10% to 90%
         export real rise=risetime(sig=V(out), initval=0.5, \
                          finalval=3.0)
         //computation of falltime for signal V(out) from 90% to 10%
         export real fall=falltime(sig=V(out), initval=3.0, \
                          finalval=0.5)
    // Print results to a specified file beginning with "to=" keyword
    print fmt ("\n****Intermediate Results of Optimization Searching****\n\n") to="mvarint.print"
    // continue to print in user-format with "addto=" keyword
    print fmt ("%-15s%-15s%-15s%-15s\n", "mp","mn","rise","fall") addto="mvarint.print"
    int mpint=1
    int mnint=1
    // definition of a mvarsearch function
    mvarsearch {
             // definition of multiple optimization goals
       	 option {
       	    accuracy = 1e-3     // convergence tolerance of trans
       	    deltax = 1e-3       // step length
       	    maxiter = 100       // limit to 100 iterations
             //  definition of multiple parameters to be optimized
       	 parameter {
       	    {mpint, 2, 1, 10} //init_val, lower_val, upper_value
       	    {mnint, 2, 1, 10} //init_val, lower_val, upper_value
             // execution of the measurement alias
       	 exec {
                mp=mpint
                mn=mnint
                print fmt("%-15e %-15e", mp, mn) addto="mvarint.print"
       	    run trans
                print fmt("%-15e%-15e\n", trans->rise,trans->fall) \
                run instParams
             // definition of goal values to be minimized
       	 zero {
       	    tmp1 = trans->rise-25p
       	    tmp2 = trans->fall-25p
    I made the parameters in the netlist mp and mn, and then optimised mpint and mnint. This seems to transfer to the netlist OK, but something really isn't working when I try this (I'm not sure the optimisation loop is correctly handling discontinuous variables).
    I don't have the bandwidth to test this more (I have vacation coming up) so I suggest you contact customer support.
  • ConradJ
    ConradJ over 3 years ago in reply to Andrew Beckett
    Thank you for your response! I agree the optimizer is having trouble with the discontinuities. I will contact support and let you know what I find. Enjoy your vacation!
    ShawnLogan over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Indeed, this will perform multiple optimizations. However, the concept is that it will produce a table with the results of each optimization. From inspection of the table, one can select the specific case that provide a global optimum.
    Although this methodology does not produce a single optimum result, it was my attempt to provide an optimal solution where the optimization algorithm does not support an integer-only constraint for the parameter to be optimized.
    It might be an alternative that may be considered pending any customer support delays.
    Shawn
