  3. print values for dc analysis
  • Subscribers 130
  • Views 6875
AndyWangsh
AndyWangsh over 2 years ago
I'm currently using spectre for the dc analysis for a simple NMOS, represented as
mn0 (d_n g_n 0 b_n) g45n1svt w=w_n l=l_n
vg_n_inst (g_n 0) vsource dc=vg_n
I would trying to save the mn0:vsat for individual vg_nvalue  to the log file or other files for the dc analysis:
dc_a dc param=vg_n start=0 stop=2 step=0.01 save=all print=yes
I also added the following at the end of scs file:
outputInfo info what=output where=logfile
element info what=inst where=logfile
However, there is no vdsat printed in the log file or elsewhere.
I tried to search over the Spectre® Simulator Fundamentals course & the spectre manual, but it seems like I cannot find the solution out there.
I'm not sure what could be the possible solution. I would expect similar results as .print mn0:vdsat if written in SPICE.
Thanks in advance.
    ShawnLogan over 2 years ago
    Dear AndyWangsh,
    According to the Spectre reference manual, the "print" argument to the dc analysis command refers to printing the node voltages and not the operating point information. If you want to observe the operating point information, I might suggest you refer to the response to the recent Forum post at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/52194/results-display-window/1384734#1384734
    There are 3 links that include a video on how to save operating point information, a troubleshooting article on the subject, and a means to print the DC oeprating point information to a file.
    Shawn
    Andrew Beckett over 2 years ago in reply to ShawnLogan
    Very simply, you can just use:
    opPoint info what=oppoint where=logfile
    (the first word doesn't really matter, as long as it is unique; it's the what=oppoint which tells it to output operating point parameters in the info analysis).
