  3. PASSIVE MIXER DESIGN
  • Subscribers 136
  • Views 9665
RFstudent
RFstudent over 3 years ago
I am starting out on doing simulations on cadence. I have materials to simulate an active mixer design, but there are none for passive. How do i start out, if i want to design a double balanced passive mixer?
    ShawnLogan over 3 years ago +1
    Dear RFstudent, RFstudent said: I have materials to simulate an active mixer design, but there are none for passive. How do i start out, if i want to design a double balanced passive mixer? You might…
  • RFstudent
    RFstudent over 3 years ago in reply to ShawnLogan +1
    Hi, Thank you so much. While the theory makes sense, I dont quite understand how to start with the simulation. How to perform dc and sp operations and how to ensure that the quad fet ring is infact…
    ShawnLogan over 3 years ago in reply to RFstudent +1
    Dear RFstudent, RFstudent said: While the theory makes sense, I dont quite understand how to start with the simulation. How to perform dc and sp operations and how to ensure that the quad fet ring is…
    Dear RFstudent,
    You might consider the following:
    K. Komoni and S. Sonkusale, "Modeling, simulation and implementation of a passive mixer in 130nm CMOS technology and scaling issues for future technologies," 2008 51st Midwest Symposium on Circuits and Systems, Knoxville, TN, USA, 2008, pp. 410-413, doi: 10.1109/MWSCAS.2008.4616823.
    Shawn
  • RFstudent
    Thank you so much. While the theory makes sense, I dont quite understand how to start with the simulation. How to perform dc and sp operations and how to ensure that the quad fet ring is infact being switched. Could you please attach a reference manual/materials, if any, it would be of great help!
    Dear RFstudent,
    When you searched the Forums, did you happen to see the following from this recent post?
    community.cadence.com/.../1388067
    There are a variety of common RF setups described in this Article on COS. SpectreRF Application Notes and Tutorials - One of our best kept secrets!    See
    RF Documentation Workshop and Database:
    • Documentation can be found here: Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer Workshop
    • ​Workshop database is located here: <SPECTRE21.1>/tools.lnx86/spectre/examples/Legacy/RF_Doc_Database.tar.gz
    It has a Mixer example which should get you started in ADE Explorer.  It doesn't cover your exact example.  For that, I recommend filing a Case on https://support.cadence.com .
    best regards,
    Tawna
    Shawn
