  3. QRC Virtuoso invoke setup
  • Views 8300
JadenMartin12
JadenMartin12 over 3 years ago
Virtuoso Version: 6.1.8
Quantus Version: 22.1.0-p089
Assura: 4.1
cshrc script:
set path = ($ASSURA_HOME/tools $path)
set path = ($QRC_HOME/tools $path)
.cdsinit script:
qrc_home=getShellEnvVar("QRC_HOME")
loadContext(strcat(qrc_home "/tools/extraction/bin/64bit/etc/context/6.1.0/64bit/aux_qrcui.cxt"))
load(strcat(qrc_home "/tools/extraction/bin/64bit/etc/context/6.1.0/64bit/qrc.ini"))
When I start the virtuoso the message says that "The Quantus UI context file was successfully loaded."
I think I followed all of the manual to invoke QRC in the virtuoso, but I can't see QRC menu when I open "Layout Suite L"
Can you give me some advice?
    Do not add those lines in the .cdsinit - they are unnecessary (in my case when I tried adding those, I get a Quantus menu but it always shows as initializating). I've no idea why you've added these as I don't believe they've ever been required.
    So my recommendation is to remove the three lines from the .cdsinit.
