  3. IC618 cannot find files to start
  • Replies 7
  • Views 18260
jeffreylao
jeffreylao over 3 years ago
Hi all,
I was trying to learn virtuoso through Cadence training, I used "Virtuoso Layout Design Basics vIC6.1.8/ICADVM20.1 (Online)" in Cadence training. With OS RHEL7.9, after downloading IC618 release and the lab files from the training course, I sourced the cshrc file(in the form of cshrc_VLDB) and set the CDSHOME to IC618 install directory. However, when I tried to start Virtuoso with command:
virtuoso &
It returns with the error:
virtuoso: error while loading shared libraries: libap_sh.so: cannot open shared object file: No such file or directory
I searched for that file and it is in the IC618 install directory:
/home/jeffrey/cadence/installs/IC618/tools.lnx86/lib/64bit/libap_sho.so
In the cshrc file, the path is set like this:
setenv LD_LIBRARY_PATH ${CDSHOME}/tools/lib
set path=($path ${CDSHOME}/tools/dfII/bin ${CDSHOME}/tools/dfII/bin/64bit ${CDSHOME}/tools/bin)
I tried adding the directory containing libap_sho.so to the path but the same error remained, in frustration I tried copying all the files in that directory to one of the directory in the path and it resolved that error. But then it asked for another missing file:
virtuoso: error while loading shared libraries: libvsacpp.so: cannot open shared object file: No such file or directory
I used the same method and find the directory and copy all the files to the directory in the path, after resolving a few more similar errors the terminals does not return anymore errors, but instead when I tried to start virtuoso nothing pops up.
I found similar issue in the community:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/31594/ic616
I tried to follow the instruction but it returns with the same error
Is there something wrong with my cshrc file? It is difficult to troubleshoot for errors, any help is appreciated
Thank you
    Andrew Beckett over 3 years ago +1
    You shouldn't need to set LD_LIBRARY_PATH and the path should not include tools/dfII/bin/64bit (the wrappers take care of this). A few things: Did you install the base release of IC618 or the latest…
    Andrew Beckett over 3 years ago in reply to jeffreylao +1
    Something sounds wrong with your installation - libPolyBool.so should be in tools.lnx86/lib/64bit - if it's not there, something probably has gone wrong during installation. If you check at the root of…
    That seems OK, but is the libPolyBool.so present in <ICinstDir>/tools.lnx86/lib/64bit ? If not, something has gone wrong. I suggest you delete your installation and re-install, starting with the hotfix…
    A few things:
    1. Did you install the base release of IC618 or the latest hotfix?
    2. What does "which virtuoso" return?
    3. What does "virtuoso -debug3264" output?
    4. Can you run "virtuoso -opt3264 -debugger3264 ldd > debugOut.txt" and then upload debugOut.txt as an attachment here (if you just paste it, it will probably flag as spam because of repeated text).
    BTW, the link to the training system was probably what initially flagged this as spam (it's not in the approved list for URLs in the forum system; it probably should be!).
  • jeffreylao
    jeffreylao over 3 years ago in reply to Andrew Beckett
    Something strange happened, I reinstalled the hotfix to see if there is something I missed, installed "ksh" and "redhat-lsb" to fix an error and a warning related to ansLibComplie(don't think it matters but it wouldn't hurt), and reboot after removing tools/dfII/bin/64bit from the path, and then the error changes, it is still asking for a missing file, but it is asking for a different file "LibPolyBool.so" now:
    /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/virtuoso: error while loading shared libraries: LibPolyBool.so: cannot open shared object file: No such file or directory
    And the location for LibPolyBool.so is:
    /home/jeffrey/cadence/installs/IC618/tools.lnx86/pcb/lib/64bit/libPolyBool.so
    1. I installed the IC618 base release first and then the hotfix, at first I have the base release but it gave me some error so I installed the hotfix afterwards.
    2. 'which virtuoso" returns
    /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/virtuoso
  • jeffreylao
    3.
    # CDS_AUTO_64BIT = ALL
    # PATH = /home/jeffrey/cadence/installs/IC618/bin:/home/jeffrey/cadence/installs/IC618/tools/bin/64bit:/home/jeffrey/cadence/installs/IC618/tools/bin:/ccstools/cdsind1/Software/PVS_PEGASUS_22.23_s009_lnx86//bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/jeffrey/.local/bin:/home/jeffrey/bin:/home/jeffrey/cadence/installs/IC618/tools/dfII/bin
    # LD_LIBRARY_PATH = /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt:/home/jeffrey/cadence/installs/IC618/tools/dfII/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/sev/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/lib:/home/jeffrey/cadence/installs/IC618/tools/hdf5/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/lz4/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/python/64bit/lib:/home/jeffrey/cadence/installs/IC618/tools/inca/lib/64bit:/home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib64:/home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib:/home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib:/home/jeffrey/cadence/installs/IC618/tools/lib/64bit/RHEL/RHEL7:/lib64
    # Launching: /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/virtuoso
    /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/virtuoso: error while loading shared libraries: libPolyBool.so: cannot open shared object file: No such file or directory
    4.
    Fullscreen debugOut.txt Download
    virtuoso:----------------------------------------------------------
    virtuoso:    INFO: Debugging: "/home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/virtuoso"
    virtuoso:
    virtuoso:          Once debugger starts up run with:
    virtuoso:
    virtuoso:                  run  ''
    virtuoso:    INFO: Launching debugger:  ldd /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/virtuoso
    	linux-vdso.so.1 =>  (0x00007fff24e96000)
    	libap_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libap_sh.so (0x00007f06650d9000)
    	libapAssist_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libapAssist_sh.so (0x00007f0664dd2000)
    	libapInfra_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libapInfra_sh.so (0x00007f0664b0d000)
    	libpl_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpl_sh.so (0x00007f0664718000)
    	libplt_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libplt_sh.so (0x00007f0664463000)
    	libadeStateXML_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeStateXML_sh.so (0x00007f0664228000)
    	libeadSpectreEmir.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libeadSpectreEmir.so (0x00007f0664007000)
    	libemircommon_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libemircommon_sh.so (0x00007f0663dda000)
    	libvsacpp.so => /home/jeffrey/cadence/installs/IC618/tools/sev/lib/64bit/libvsacpp.so (0x00007f06609cf000)
    	libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f06607b3000)
    	libpython3.6m.so.1.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpython3.6m.so.1.0 (0x00007f066027a000)
    	libvpsl.so => /home/jeffrey/cadence/installs/IC618/tools/sev/lib/64bit/libvpsl.so (0x00007f065fff9000)
    	libemirresultsbrowser.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libemirresultsbrowser.so (0x00007f065fb9a000)
    	libtungsten.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtungsten.so (0x00007f065f3de000)
    	libwdbh5.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libwdbh5.so (0x00007f065f0e2000)
    	libemirresults.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libemirresults.so (0x00007f065ee8b000)
    	libtungstencommon.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtungstencommon.so (0x00007f065ebe5000)
    	libqtermwidget.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libqtermwidget.so (0x00007f065e8c7000)
    	libtungsten_il.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtungsten_il.so (0x00007f065e6bf000)
    	libcthDRM.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcthDRM.so (0x00007f065b286000)
    	libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f065b04f000)
    	libxerces-c-3.1.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libxerces-c-3.1.so (0x00007f065a9c3000)
    	libcrypto.so.10 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcrypto.so.10 (0x00007f065a5e3000)
    	libPolyBool.so => not found
    	libprotobuf.so.3.12.2.0 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib64/libprotobuf.so.3.12.2.0 (0x00007f0659ccb000)
    	libgrpc++.so.1 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libgrpc++.so.1 (0x00007f065990d000)
    	libgrpc.so.11 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libgrpc.so.11 (0x00007f0658fbc000)
    	libaddress_sorting.so.11 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libaddress_sorting.so.11 (0x00007f0658db8000)
    	libre2.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib64/libre2.so (0x00007f0658a5c000)
    	libupb.so.11 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libupb.so.11 (0x00007f065884f000)
    	libz.so.1 => /lib64/libz.so.1 (0x00007f0658639000)
    	libabsl_bad_optional_access.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_bad_optional_access.so (0x00007f0658436000)
    	libgpr.so.11 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libgpr.so.11 (0x00007f065821e000)
    	libabsl_str_format_internal.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_str_format_internal.so (0x00007f0657fe1000)
    	libabsl_time.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_time.so (0x00007f0657db7000)
    	libabsl_time_zone.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_time_zone.so (0x00007f0657b6b000)
    	libabsl_civil_time.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_civil_time.so (0x00007f0657966000)
    	libabsl_strings.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_strings.so (0x00007f0657735000)
    	libabsl_strings_internal.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_strings_internal.so (0x00007f0657530000)
    	libabsl_throw_delegate.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_throw_delegate.so (0x00007f065732a000)
    	libabsl_int128.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_int128.so (0x00007f0657121000)
    	libabsl_base.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_base.so (0x00007f0656f19000)
    	libabsl_spinlock_wait.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_spinlock_wait.so (0x00007f0656d16000)
    	libabsl_raw_logging_internal.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_raw_logging_internal.so (0x00007f0656b12000)
    	libabsl_log_severity.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_log_severity.so (0x00007f0656910000)
    	libabsl_dynamic_annotations.so => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libabsl_dynamic_annotations.so (0x00007f065670d000)
    	libssl.so => not found
    	libcrypto.so => not found
    	libgrpc++_reflection.so.1 => /home/jeffrey/cadence/installs/IC618/tools/TPtools/grpc/lib/libgrpc++_reflection.so.1 (0x00007f0656453000)
    	libsqlite3.so.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsqlite3.so.0 (0x00007f0656109000)
    	libresdb.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libresdb.so (0x00007f0655ba4000)
    	libSchSpfNameMap.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libSchSpfNameMap.so (0x00007f065598b000)
    	libadeUtils.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeUtils.so (0x00007f0655765000)
    	libadeUtils_oa.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeUtils_oa.so (0x00007f0655548000)
    	libdspf_namemap_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdspf_namemap_sh.so (0x00007f0655334000)
    	librt.so.1 => /lib64/librt.so.1 (0x00007f065512c000)
    	libvirtuos_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvirtuos_sh.so (0x00007f0654ef2000)
    	libfastt_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libfastt_sh.so (0x00007f0654cef000)
    	libcls_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcls_sh.so (0x00007f0654ade000)
    	libcdsCommon_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcdsCommon_sh.so (0x00007f06548b9000)
    	liboaPrivateCDS.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaPrivateCDS.so (0x00007f06546b0000)
    	liboaDesign.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaDesign.so (0x00007f0653bd9000)
    	liboaDM.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaDM.so (0x00007f06538e6000)
    	liboaCM.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaCM.so (0x00007f06536ae000)
    	liboaTech.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaTech.so (0x00007f0653268000)
    	liboaPlugIn.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaPlugIn.so (0x00007f0653056000)
    	liboaBase.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaBase.so (0x00007f06529da000)
    	liboaCommon.so => /home/jeffrey/cadence/installs/IC618/share/oa/lib/lnx86/opt/liboaCommon.so (0x00007f06527aa000)
    	libshdb_verilog.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libshdb_verilog.so (0x00007f0652574000)
    	libihdlGrUtils_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libihdlGrUtils_sh.so (0x00007f065232b000)
    	libihdl_nc_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libihdl_nc_sh.so (0x00007f06520a6000)
    	libihdl_db_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libihdl_db_sh.so (0x00007f0651e43000)
    	libihdl_schgen_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libihdl_schgen_sh.so (0x00007f0651c17000)
    	libtiParseSpice.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtiParseSpice.so (0x00007f06519ee000)
    	libshdb_spice.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libshdb_spice.so (0x00007f06517de000)
    	libshdb_cdl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libshdb_cdl.so (0x00007f06515d7000)
    	libtiParseCdl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtiParseCdl.so (0x00007f06513cb000)
    	libti5xBase.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libti5xBase.so (0x00007f065118c000)
    	libshdb_format.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libshdb_format.so (0x00007f0650f6b000)
    	libshdb_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libshdb_core.so (0x00007f0650d4b000)
    	libddpiServices_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libddpiServices_sh.so (0x00007f0650b02000)
    	libddpi_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libddpi_sh.so (0x00007f06508ed000)
    	libddbase_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libddbase_sh.so (0x00007f065066f000)
    	libil_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libil_sh.so (0x00007f06502cc000)
    	libnmpil_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libnmpil_sh.so (0x00007f065007f000)
    	libgdm_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libgdm_sh.so (0x00007f064fe6d000)
    	libgdmil_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libgdmil_sh.so (0x00007f064fc66000)
    	libccp_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libccp_sh.so (0x00007f064f9d2000)
    	libpcdb_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpcdb_sh.so (0x00007f064f781000)
    	libckp_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libckp_sh.so (0x00007f064f566000)
    	libdataReg_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdataReg_sh.so (0x00007f064f353000)
    	libddAccess_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libddAccess_sh.so (0x00007f064f141000)
    	libdsCat_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdsCat_sh.so (0x00007f064ef1b000)
    	libnmp_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libnmp_sh.so (0x00007f064eccf000)
    	libcla_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcla_sh.so (0x00007f064eaa4000)
    	libcdsIlIpc_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcdsIlIpc_sh.so (0x00007f064e893000)
    	libmpsc_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libmpsc_sh.so (0x00007f064e670000)
    	libsman_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsman_sh.so (0x00007f064e45a000)
    	libmpss_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libmpss_sh.so (0x00007f064e241000)
    	libmpi_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libmpi_sh.so (0x00007f064e017000)
    	liblbss_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liblbss_sh.so (0x00007f064de06000)
    	libem_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libem_sh.so (0x00007f064dc00000)
    	liblbsc_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liblbsc_sh.so (0x00007f064d9d0000)
    	libems_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libems_sh.so (0x00007f064d7b7000)
    	libemscpp_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libemscpp_sh.so (0x00007f064d5a8000)
    	libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007f064d2e9000)
    	libcdsQt5Test.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Test.so.5 (0x00007f06659cc000)
    	libxcf_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libxcf_sh.so (0x00007f064d0e0000)
    	lib_cadencehelp.so.2 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/lib_cadencehelp.so.2 (0x00007f064ceb3000)
    	libcdsQt5Core.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Core.so.5 (0x00007f064c8b7000)
    	libcdsQt5Gui.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Gui.so.5 (0x00007f064c2d2000)
    	libcdsQt5Widgets.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Widgets.so.5 (0x00007f064bc4a000)
    	libcdsQt5X11Extras.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5X11Extras.so.5 (0x00007f06659c4000)
    	libGLU.so.1 => /lib64/libGLU.so.1 (0x00007f064b9ca000)
    	libGL.so.1 => /lib64/libGL.so.1 (0x00007f064b73e000)
    	libXrender.so.1 => /lib64/libXrender.so.1 (0x00007f064b533000)
    	libXext.so.6 => /lib64/libXext.so.6 (0x00007f064b321000)
    	libX11.so.6 => /lib64/libX11.so.6 (0x00007f064afe3000)
    	libX11-xcb.so.1 => /lib64/libX11-xcb.so.1 (0x00007f064ade1000)
    	libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f064abb9000)
    	libXss.so.1 => /lib64/libXss.so.1 (0x00007f064a9b5000)
    	libXft.so.2 => /lib64/libXft.so.2 (0x00007f064a79f000)
    	libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007f064a55d000)
    	libhedElaborator_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhedElaborator_sh.so (0x00007f064a215000)
    	libhdb_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhdb_sh.so (0x00007f0649ef6000)
    	libhed_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhed_sh.so (0x00007f0649a7c000)
    	libhedCopy_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhedCopy_sh.so (0x00007f0649873000)
    	libviva_ade.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libviva_ade.so (0x00007f064966b000)
    	libvivadf2.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvivadf2.so (0x00007f0649342000)
    	libviva.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libviva.so (0x00007f0647784000)
    	libedser_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libedser_sh.so (0x00007f064757a000)
    	libclalite_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libclalite_sh.so (0x00007f0647351000)
    	libhdbcla_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhdbcla_sh.so (0x00007f0647047000)
    	libpcdbclaNoOA_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpcdbclaNoOA_sh.so (0x00007f0646e08000)
    	libcolumnFilter.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcolumnFilter.so (0x00007f0646bc5000)
    	libdrl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdrl.so (0x00007f064613f000)
    	libadt.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadt.so (0x00007f0645f20000)
    	libdalil.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdalil.so (0x00007f0645cd7000)
    	libvivaQuickPlot.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvivaQuickPlot.so (0x00007f0645ac9000)
    	libpsf.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpsf.so (0x00007f0644f96000)
    	liblz4.so.1 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liblz4.so.1 (0x00007f0644d7d000)
    	libblosc.so.1 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libblosc.so.1 (0x00007f0644b30000)
    	libz_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libz_sh.so (0x00007f0644916000)
    	libsrr.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsrr.so (0x00007f0643ab9000)
    	libcdsenvutil.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcdsenvutil.so (0x00007f0643895000)
    	libcdsenvxml.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcdsenvxml.so (0x00007f0643669000)
    	libdavr.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdavr.so (0x00007f0643423000)
    	libgfortran.so.3 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libgfortran.so.3 (0x00007f06430fc000)
    	liboccprop_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liboccprop_sh.so (0x00007f0642ec4000)
    	liboccprophdb_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liboccprophdb_sh.so (0x00007f0642c8a000)
    	libXt.so.6 => /lib64/libXt.so.6 (0x00007f0642a23000)
    	libcdsQt5OpenGL.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5OpenGL.so.5 (0x00007f066595b000)
    	libcdsQt5Svg.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Svg.so.5 (0x00007f0665900000)
    	libcdsQt5Sql.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Sql.so.5 (0x00007f06658b5000)
    	libcdsQt5Xml.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Xml.so.5 (0x00007f0665877000)
    	libcdsQt5XmlPatterns.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5XmlPatterns.so.5 (0x00007f0642642000)
    	libcdsQt5PrintSupport.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5PrintSupport.so.5 (0x00007f06425ce000)
    	libcdsQt5Network.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Network.so.5 (0x00007f0642430000)
    	libcdsQt5Concurrent.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Concurrent.so.5 (0x00007f066586e000)
    	libxalan-c.so.111 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libxalan-c.so.111 (0x00007f0641d90000)
    	libxalanMsg.so.111 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libxalanMsg.so.111 (0x00007f0641b87000)
    	libcfdeicpkg.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcfdeicpkg.so (0x00007f0641953000)
    	libparAppDef.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libparAppDef.so (0x00007f0641742000)
    	libutility.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libutility.so (0x00007f0641448000)
    	libheartbeatThread.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libheartbeatThread.so (0x00007f0641243000)
    	libpapi_verilog.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpapi_verilog.so (0x00007f0641033000)
    	libpapi_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpapi_core.so (0x00007f0640dd0000)
    	libpapi_spice.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpapi_spice.so (0x00007f0640bc3000)
    	libconn_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libconn_core.so (0x00007f0640999000)
    	libconn_vhdl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libconn_vhdl.so (0x00007f0640788000)
    	libconn_vlog.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libconn_vlog.so (0x00007f064055f000)
    	libconn_spice.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libconn_spice.so (0x00007f0640347000)
    	libpcdb_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpcdb_core.so (0x00007f064013a000)
    	libcdf_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libcdf_core.so (0x00007f063ff35000)
    	libsch_core.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsch_core.so (0x00007f063fd31000)
    	libpcdb_vlog.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpcdb_vlog.so (0x00007f063fb25000)
    	libtiParseVhdl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtiParseVhdl.so (0x00007f063f919000)
    	libpapi_cdl.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpapi_cdl.so (0x00007f063f713000)
    	libpcPlugin_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpcPlugin_sh.so (0x00007f063f4e1000)
    	libasa.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libasa.so (0x00007f063f247000)
    	libapa.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libapa.so (0x00007f063efcb000)
    	libte.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libte.so (0x00007f063ec61000)
    	libopc.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libopc.so (0x00007f063e9a9000)
    	libopcUtils.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libopcUtils.so (0x00007f063e721000)
    	libdebugUtils.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdebugUtils.so (0x00007f063e51e000)
    	libdl.so.2 => /lib64/libdl.so.2 (0x00007f063e31a000)
    	libverifier.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libverifier.so (0x00007f063d5fb000)
    	libdfii_json.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdfii_json.so (0x00007f063d3de000)
    	libdfii_json_skill.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdfii_json_skill.so (0x00007f063d1c8000)
    	libSchSpfNameMap_il.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libSchSpfNameMap_il.so (0x00007f063cfbd000)
    	libadeDiagnostics.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeDiagnostics.so (0x00007f063cc53000)
    	libadeDiagnostics_il.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeDiagnostics_il.so (0x00007f063ca4f000)
    	libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f063c835000)
    	libelf.so.1 => /lib64/libelf.so.1 (0x00007f063c61d000)
    	libstdc++.so.6 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libstdc++.so.6 (0x00007f063c29c000)
    	libm.so.6 => /lib64/libm.so.6 (0x00007f063bf9a000)
    	libgcc_s.so.1 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libgcc_s.so.1 (0x00007f063bd83000)
    	libc.so.6 => /lib64/libc.so.6 (0x00007f063b9b5000)
    	/lib64/ld-linux-x86-64.so.2 (0x00007f066581f000)
    	libssl.so.10 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libssl.so.10 (0x00007f063b749000)
    	libuuid.so.1 => /lib64/libuuid.so.1 (0x00007f063b544000)
    	libutil.so.1 => /lib64/libutil.so.1 (0x00007f063b341000)
    	libyaml-cpp.so.0.6 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/yaml-cpp/lib/64bit/libyaml-cpp.so.0.6 (0x00007f063b042000)
    	libcdsQt5Charts.so.5 => /home/jeffrey/cadence/installs/IC618/tools/Qt/v5/64bit/lib/libcdsQt5Charts.so.5 (0x00007f063aebd000)
    	libhdf5_cpp.so.200 => /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/../../../hdf5/lib/64bit/libhdf5_cpp.so.200 (0x00007f063ac55000)
    	libhdf5.so.200 => /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/../../../hdf5/lib/64bit/libhdf5.so.200 (0x00007f063a4cb000)
    	libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f063a2bb000)
    	libfreebl3.so => /lib64/libfreebl3.so (0x00007f063a0b8000)
    	libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f0639e4e000)
    	libdataPoint.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdataPoint.so (0x00007f0639c34000)
    	libboost_serialization.so.1.64.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/boost/lib/64bit/libboost_serialization.so.1.64.0 (0x00007f06399f7000)
    	libboost_program_options.so.1.64.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/boost/lib/64bit/libboost_program_options.so.1.64.0 (0x00007f063977b000)
    	libamps.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libamps.so (0x00007f0639471000)
    	libstatdb.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libstatdb.so (0x00007f0638cdd000)
    	libLogApi.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLogApi.so (0x00007f0638ad9000)
    	libaxlEmsApi.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libaxlEmsApi.so (0x00007f06388d7000)
    	libLogRunTimeInfo.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLogRunTimeInfo.so (0x00007f06386b9000)
    	libdavConversion.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdavConversion.so (0x00007f06384b2000)
    	libpng15.so.15 => /lib64/libpng15.so.15 (0x00007f0638287000)
    	libgthread-2.0.so.0 => /lib64/libgthread-2.0.so.0 (0x00007f0638085000)
    	libglib-2.0.so.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/RHEL/RHEL7/libglib-2.0.so.0 (0x00007f0637d6f000)
    	libGLX.so.0 => /lib64/libGLX.so.0 (0x00007f0637b3d000)
    	libGLdispatch.so.0 => /lib64/libGLdispatch.so.0 (0x00007f0637887000)
    	libXau.so.6 => /lib64/libXau.so.6 (0x00007f0637683000)
    	libexpat.so.1 => /lib64/libexpat.so.1 (0x00007f0637459000)
    	libvCalc.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvCalc.so (0x00007f0637248000)
    	libvaxEdgeDB.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvaxEdgeDB.so (0x00007f063701d000)
    	libvaxMeas.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvaxMeas.so (0x00007f0636e09000)
    	libvaxEdgeXML.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvaxEdgeXML.so (0x00007f0636bff000)
    	libfftw3.so.3 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libfftw3.so.3 (0x00007f0636809000)
    	libfftw3_threads.so.3 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libfftw3_threads.so.3 (0x00007f0636601000)
    	libquadmath.so.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libquadmath.so.0 (0x00007f06363c1000)
    	libSM.so.6 => /lib64/libSM.so.6 (0x00007f06361b9000)
    	libICE.so.6 => /lib64/libICE.so.6 (0x00007f0635f9d000)
    	libenv_sh.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libenv_sh.so (0x00007f0635d6e000)
    	libZipLib.so => /home/jeffrey/cadence/installs/IC618/tools/dfII/bin/64bit/../../../TPtools/zipLib/lib/64bit/libZipLib.so (0x00007f0635ae9000)
    	libhistubs.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libhistubs.so (0x00007f06358e7000)
    	libjansson.so.4 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/jansson/lib/64bit/libjansson.so.4 (0x00007f06356d6000)
    	libboost_iostreams.so.1.64.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/boost/lib/64bit/libboost_iostreams.so.1.64.0 (0x00007f06354c2000)
    	libboost_filesystem.so.1.64.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/boost/lib/64bit/libboost_filesystem.so.1.64.0 (0x00007f06352a9000)
    	libsetupdb.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsetupdb.so (0x00007f0634e11000)
    	libpointstrategy.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpointstrategy.so (0x00007f06346a4000)
    	libsession.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsession.so (0x00007f063407b000)
    	libguicommon.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libguicommon.so (0x00007f0633d65000)
    	libsla.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libsla.so (0x00007f0633aa5000)
    	libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f0633858000)
    	libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f063356f000)
    	libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f063336b000)
    	libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f0633138000)
    	libidn.so.11 => /lib64/libidn.so.11 (0x00007f0632f05000)
    	libssh2.so.1 => /lib64/libssh2.so.1 (0x00007f0632cd8000)
    	libssl3.so => /lib64/libssl3.so (0x00007f0632a73000)
    	libsmime3.so => /lib64/libsmime3.so (0x00007f063284b000)
    	libnss3.so => /lib64/libnss3.so (0x00007f0632511000)
    	libnssutil3.so => /lib64/libnssutil3.so (0x00007f06322e1000)
    	libplds4.so => /lib64/libplds4.so (0x00007f06320dd000)
    	libplc4.so => /lib64/libplc4.so (0x00007f0631ed8000)
    	libnspr4.so => /lib64/libnspr4.so (0x00007f0631c99000)
    	liblber-2.4.so.2 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liblber-2.4.so.2 (0x0000003247c00000)
    	libldap-2.4.so.2 => /lib64/libldap-2.4.so.2 (0x00007f0631a44000)
    	libavrocpp.so.1.8.2.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/avro/lib/64bit/libavrocpp.so.1.8.2.0 (0x00007f063175b000)
    	libbeanstalk.so.1 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/beanstalkClient/lib/64bit/libbeanstalk.so.1 (0x00007f0631546000)
    	libstatdbutils.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libstatdbutils.so (0x00007f0631332000)
    	libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f06310d0000)
    	libboost_system.so.1.64.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/boost/lib/64bit/libboost_system.so.1.64.0 (0x00007f0630ecb000)
    	libparameters.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libparameters.so (0x00007f0630c17000)
    	libjobmanager.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libjobmanager.so (0x00007f0630582000)
    	libalchemy.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libalchemy.so (0x00007f063006b000)
    	libexpressionevaluator.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libexpressionevaluator.so (0x00007f062fdd2000)
    	libpointevaluator.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libpointevaluator.so (0x00007f062f9d1000)
    	libtxtviewer.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libtxtviewer.so (0x00007f062f7b7000)
    	libvvo.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvvo.so (0x00007f062f43a000)
    	libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f062f220000)
    	libXi.so.6 => /lib64/libXi.so.6 (0x00007f062f010000)
    	liboldstatdb.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/liboldstatdb.so (0x00007f062ec91000)
    	libLog4cxxCiwAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxCiwAppender.so (0x00007f062ea84000)
    	libLog4cxxEmsCiwAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxEmsCiwAppender.so (0x00007f062e878000)
    	libloggingServiceGrpcTarget.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libloggingServiceGrpcTarget.so (0x00007f062e66e000)
    	libloggingDatabase.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libloggingDatabase.so (0x00007f062e42a000)
    	libLog4cxxRdbServiceAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxRdbServiceAppender.so (0x00007f062e221000)
    	libLog4cxxNullAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxNullAppender.so (0x00007f062e018000)
    	libvivaServiceGrpcAPI.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvivaServiceGrpcAPI.so (0x00007f062ddbc000)
    	libadeBrokerDeamonAPI.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeBrokerDeamonAPI.so (0x00007f062daf7000)
    	libspecEngine.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libspecEngine.so (0x00007f062d8c9000)
    	libvivaServiceCommon.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libvivaServiceCommon.so (0x00007f062d6a5000)
    	libaxlEmsApiLog.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libaxlEmsApiLog.so (0x00007f062d49f000)
    	libLogApiInit.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLogApiInit.so (0x00007f062d295000)
    	libadeservice.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeservice.so (0x00007f062d063000)
    	libadeservicemanager.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libadeservicemanager.so (0x00007f062ce3c000)
    	libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f062cc2c000)
    	libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f062ca27000)
    	libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007f062c80a000)
    	libYamlConfig.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libYamlConfig.so (0x00007f062c5e9000)
    	liblog4cxx.so.10 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/../../TPtools/log4cxx/lib/64bit/liblog4cxx.so.10 (0x00007f062c157000)
    	libLog4cxxLoggingServiceAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxLoggingServiceAppender.so (0x00007f062bf41000)
    	libloggingServiceGrpcAPI.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libloggingServiceGrpcAPI.so (0x00007f062bd09000)
    	libLog4cxxFileAppender.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLog4cxxFileAppender.so (0x00007f062bafa000)
    	libLogApiLog4cxx.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libLogApiLog4cxx.so (0x00007f062b8f1000)
    	libjsonUtility.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libjsonUtility.so (0x00007f062b6e7000)
    	libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f062b4bf000)
    	libaprutil-1.so.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libaprutil-1.so.0 (0x00007f062b29b000)
    	libapr-1.so.0 => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libapr-1.so.0 (0x00007f062b06d000)
    	libdb-4.7.so => /home/jeffrey/cadence/installs/IC618/tools/lib/64bit/libdb-4.7.so (0x00007f062acf9000)
    Thank you for your help
    Something sounds wrong with your installation - libPolyBool.so should be in tools.lnx86/lib/64bit - if it's not there, something probably has gone wrong during installation. If you check at the root of your installation by doing:
    ls -l install/pkgs/polybool*
    and see what it returns?
    In general you don't to install the base and then the hotfix - just installing the hotfix is sufficient (it will download anything from the base release that is still needed).
    In addition, you have two additional packages you'll need to install on your OS since it's complaining about libcrypto.so and libssl.so . These come from the glibc-devel and openssl-devel RPMs respectively (the 64bit versions).
  • jeffreylao
    "ls -l install/pkgs/polybool*" returns
    install/pkgs/polybool_lnx8621.00-s005lnx86.ok
    As for the other files, I have previously installed glibc-devel but not openssl-devel, I just installed openssl-devel and the only file 'not found" in debugOut.txt is libPolyBool.so
    That seems OK, but is the libPolyBool.so present in <ICinstDir>/tools.lnx86/lib/64bit ? If not, something has gone wrong. I suggest you delete your installation and re-install, starting with the hotfix (I always install by using iscape rather than downloading complete images, as that's much more efficient; it just downloads the packages it needs).
  • jeffreylao
    This issue has been resolved. Looks like my problem is that I assumed 'Base' release to be the software itself and 'hotfix' release to be the bug fix and new features and so the installation always run into problems after installing both of them.
    I started a new virtual machine with only the hotfix installed, I got a bit further this time and run into a licensing error, in any case it is a different error now. Thanks a lot for your help, saved me a lot of time and frustration.Thumbsup
