  3. How to parametrize number of instances in Virtuoso
  • Views 7723
mxm14
mxm14 over 3 years ago
Hello!
I was wondering if there is a way to parametrize the number of parallel instances of a cell in Virtuoso.
I would like to have <N:0> inverters with N as parameter. Is there a simple way to do that?
Thank you in advance
    No, there's no simple way to do this. You'd have to create a schematic PCell to achieve this (which involves a bit of work). You could potentially add an m-factor instead on the instance, but that's not going to necessarily be supported in all flows (it rather depends on what you're doing).
