  3. Issue about config copy
  • Views 6658
sjwprcker
sjwprcker over 3 years ago
I would like to copy config_A to config_B. There are some cell views defined in "Tree View" format using Occurences. For inistance, a DFF is used in different places, some DFF adopts schematic view, and some other DFF adopts verilogams view.
When the view is copied, all those Occurences feature is lost. I have to manually set them again which is very time-wasting.
Is there anyway to force copy Occurence feature when copying config?
Thanks for your help.
    Did you check the "Update instances" checkbox on the copy form when you did the copy in the library manager? I would expect that to sort out any occurrences in the config (otherwise they might continue pointing to the original data). I would not expect occurrence bindings to be lost.
    Also, which IC sub-version are you using?
