  3. Unable to figure out the following error: "xmelab: *E,NOUNIT...
  • Subscribers 136
  • Views 3991
Unable to figure out the following error: "xmelab: *E,NOUNIT"
akaraguppi
akaraguppi over 3 years ago
I am running a boost converter transient simulation (liberal) using AMS simulator in ADE assembler. It has several verilogA and verilogAMS blocks along with other analog blocks. This was working fine until I began encountering these errors. I didn't change my circuit or modify my simulator settings. I am not sure how to get around it. Also, turns out that with the exact same simulator settings the same test bench works on my colleague's machine. I am not sure what is different.
Screenshot of the error:
I also checked again and again that the schematic file that it is pointing out in the log file does exist. I am not sure why it is unable to find it.
Simulator settings:
  • akaraguppi
    Issue resolved. It was an LSF run policy issue. Kindly ignore this post.
