  3. ParaViwe from EMX GUI 6.3 issue
  • Subscribers 129
  • Views 6827
NewScreenName
NewScreenName over 2 years ago
Dear all,
I am trying to visualize the mesh of a layout simulated with EMX 6.3 from the GUI of ICADVM20.1-64b.500.33. To do this I have:
1) verified my system's compatibility as described here: Setting up Paraview in EMX 6.0, 6.1, and 6.2 (cadence.com)
2)  run successfully the command checkSysConf EMX6.3 as described here: How can I tell if my workstation has the correct patches and OS configuration in order to run EMX? (cadence.com)
3) created my local emxconfig.il as described at point 1 with proper settings
4) followed what explained at module 5 from EMX6.3: Introduction to EMX Planar 3D Solver (cadence.com)
What I get when  I press the "mesh" button is that paraview 5.7 opens, but although all the settings in the window are as described by the document of point 4, the Layout #1 tab, renderview remains blank. Even opening a new layout tab and trying for example the render view button again does not help.
Am I missing some settings/steps? I would not know what else to check to get the mesh visualization.
Thank you
Regards
    It sounds like you've done the obvious steps. I suggest you contact customer support - will be much easier for us to check what's going on that way (submit a case after logging in).
