  3. Quantus Release Version 19.13 ERROR (EXTQRCXLOG-108) : ...
  • Views 7187
Quantus Release Version 19.13 ERROR (EXTQRCXLOG-108) : [solved]
hesaliveJim
hesaliveJim over 3 years ago
I was wondering if Quantus Release Version 19.13 will work with IC6.17?
If not which version.
At the moment I get this message:
ERROR (EXTQRCXLOG-108) : Exiting due to a error reported by the operating system's runtime
environment:
basic_string::_S_construct null not valid
whatever that means?
    Andrew Beckett over 3 years ago +1
    A few reports of similar crashes. I don't think it's related to the version combination used - the more likely reason appears to be a lack of disk space (maybe in the run directory, but could also be in…
    A few reports of similar crashes. I don't think it's related to the version combination used - the more likely reason appears to be a lack of disk space (maybe in the run directory, but could also be in /tmp). See Quantus exiting due to error reported by the operating system (EXTQRCXLOG-108)
  • hesaliveJim
    hesaliveJim over 3 years ago in reply to Andrew Beckett
    Andrew thank you that solved as you suggested disk space was lacking.
