  3. Errors exist in master control file [solved]
  • Views 7653
hesaliveJim
hesaliveJim over 3 years ago
Following successful LVS.
I now get this error:
  Cadence Quantus Extraction - 64-bit Parasitic Extractor - Version
19.1.3-s062 Tue Jul 23 02:42:20 PDT 2019
                                  Copyright 2019 Cadence Design Systems,
Inc.
INFO (LBRCXM-699): Errors exist in master control file "/tmp/qrc_25065/1/__qrc.rcx_cmd".
ERROR (LBRCXM-709): *****  Quantus terminated abnormally  *****
Not sure what to do? I cannot see what's wrong with this file.
    Andrew Beckett over 3 years ago +1
    Is your cell name numeric? If so, this is a known issue: Quantus run crashes with Errors exist in master control file “__qrc.rcx_cmd” for numeric cellname Andrew
  • hesaliveJim
    hesaliveJim over 3 years ago in reply to Andrew Beckett
    yes I have renamed the file and it runs just fine, thank you Andrew.
    I've marked it solved just in case somebody else names their file numerically!
