  3. ADE L ERROR
  • Subscribers 130
  • Views 7315
ADE L ERROR
Psyliver
Psyliver over 2 years ago
Hellow, I try to run ADEL after i installed the new version of cadence and this error pops up "ERROR (ADE-5704): Variable 'options faultDoSampling' is either not declared or does not exist
for analysis 'tran'."
Kindly if someone could help me rectify this problem, i will be very grateful
    ShawnLogan over 2 years ago
    Dear Psyliver,
    You did not indicate the version of the Cadence tools are the "new version", but are you aware that ADE-L is no longer supported? It has been replaced with ADE Assembler and Explorer. Perhaps you are trying to run ADE-L in a version of the Cadence tools that no longer support it.
    Shawn
    Andrew Beckett over 2 years ago in reply to ShawnLogan
    Shawn, @Psylver
    Whilst ADE L is past end-of-sale, you wouldn't get that error if running in a version that didn't contain ADE L (because you wouldn't be able to run it).
    The issue is (I believe) that you are running with too old a version of Spectre. Please state which IC sub-version and Spectre sub-version you're using (virtuoso -W and spectre -W from the UNIX command line will tell you this).
  • Psyliver
    Psyliver over 2 years ago in reply to Andrew Beckett
    The problem has been resolved. The spectre version was from 2017 and that was responsible for the error. I upadated it and it is working.
    Many Thanks
