  3. Autostop in Maestro after evaluating all measurements
  • Subscribers 129
  • Views 5956
Ejcxuralsshdd
Ejcxuralsshdd over 2 years ago
Hi
I have over 80 measuremnts inside Maestro. I want to stop given transient run after it has calculated all 80 measurements.
As per my knowlege, Spectre autostop only on event condition. One of the way to do this is using MDL. But i never personally used SpectreMDL and i dont know if Maestro expressions syntax are valid in Spectremdl.
Can someone suggest best approach to solve my issue ?
    This doesn't make any sense. The expressions in the maestro view are evaluated after the simulation has finished, so there's nothing to stop let alone auto-stop. If you need the simulation to stop, then you'd have to use SpectreMDL (no, maestro expressions are no the same syntax), or you'd need to do your checks in a Verilog-A module which could call $finish_current_analysis() when the condition to stop is met.
