  3. Quantus terminated normally yet produced errors. [resolved...
  • Views 6953
Quantus terminated normally yet produced errors. [resolved]
hesaliveJim
hesaliveJim over 3 years ago
I'm using EXT19.13 following successful LVS.
I get this error at the end of QRC log:
# Flatten net file, routing, via and device layers
beginFlattenInputs
/bin/mv -f NET h_NET
flatnet -V -li -h / h_NET NET
flatnet took 0.01 user, 0.01 sys, 0.00 elapsed, 12640.0 kbytes
netprint -V -N1 power_list:power_list_nums NET
flattenTransistorData NGO2LLST_025_0FINAL microns
INFO (LBRCXM-610): Extraction finished.
flattub took  0.00 user, 0.01 sys, 0.00 elapsed, 5588.0 kbytes
INFO (LBRCXM-582): Checking in license of QTS300 19.10
INFO (LBRCXM-702): Run ended: Tue Oct 24 19:41:20 2023
INFO (LBRCXM-805): Run took: 8s elapsed
INFO (LBRCXM-708): *****  Quantus terminated normally  *****
ERROR (LBMISC-215052): cannot create XXXtemp109752: No such file or directory
ERROR (FLTTDTA-109004): Forked flatnet command failed.
ERROR (LBMISC-215251): Error: command failed with status 255
I wonder why I get these errors?
#using Virtuoso IC6.1.7 Quantus Extraction program 19.1.3
Since posting the problem has gone away -  not sure what I did but glad its decided to go away.
Would be nice to delete this post.
