  3. Why framed mode simlinkCoupler reports error in AMS-MATLAB...
  • Views 7224
Why framed mode simlinkCoupler reports error in AMS-MATLAB co-simulation
SpiceMonkey
SpiceMonkey over 3 years ago
It works well if I use unframed mode. When I use framed mode, SimCoupler reports error:
Error in block 'untitled/SimulinkCoupler': ERROR (SIMLNK-48): An unframed signal cannot be connected to the input port 0 (counting from 0) while the s-function parameter Frame mode is set to 'framed'.
Ensure that all blocks connected to the coupler are either all framed or all unframed.Error reported by S-function 'SimCoupler' in 'untitled/SimulinkCoupler':
This is my Simulink test bench, I have use [Buffer] to convert [Sine Wave]'s sampled signal to be framed one. Could anyone help?
(simCoupler.mdl and mex files are form IC618, Matlab 2021b)
  • SpiceMonkey
    Additional Information,When I copy [Buffer] from workshop sample, it works. When I add [Buffer] from Simulink Library, NO WORK!
    Andrew Beckett over 3 years ago in reply to SpiceMonkey
    Please contact customer support.
  • SpiceMonkey
    Inserting a block [Frame Conversion] after [Buffer] solved the problem.
