  3. Maestro - output setup doesn't refresh expressions
  • Views 2978
firebolt2
firebolt2 over 3 years ago
Somehow my Maestro Output Setup fails to show edited expressions on the fly. It shows old entries unless I descend into any test by clicking arrow and come back. In this way it refreshes output expressions. This is a strange behaviour and happens frequently, but not always. How to fix it? Please help. virtuoso version 6.1.8-64b
    Andrew Beckett over 3 years ago in reply to firebolt2 +1
    The specific issue I was thinking of where this was particularly a problem was fixed in IC6.1.8.500.28 - so after the version you're using. Andrew
    This behaviour did happen in certain older versions of IC6.1.8 - your version number is not terribly specific - that could be anything from 5 years of different hotfix versions. Anyway, as far as I know this has been fixed for a while (I'm not aware of any current issues). Can you state the sub-version number (Help→About will show this, as will calling getVersion(t) in the CIW).
  • firebolt2
    firebolt2 over 3 years ago in reply to Andrew Beckett
    sub-version IC6.1.8-64b.500.26
  • firebolt2
    Thank you. I will check with my local admin.
