  3. How to execute runSimulation script not in other paths
  • Subscribers 136
  • Views 8667
SpiceMonkey
SpiceMonkey over 3 years ago
Deer All,
I have generated AMS netlist using ADE, there is a ksh script "runSimulation" in "/simPath/designName/ams/config/netlist"
First cd /simPath/designName/ams/config/netlist, then ./runSimulation, simulation run successfully.
While, if current directory is not under "*/netlist", execute "/absultePath/runSimulation" reports many files couldn't be found. Is there an elegant way to run this script in other directories?
Thank you!
    Andrew Beckett over 3 years ago in reply to ShawnLogan +1
    First of all, this is not really a supported flow - the runSimulation script is a means to an end in the simulation flow, and it's not really there for you to run batch simulations afterwards. If you want…
    ShawnLogan over 3 years ago
    Dear SpiceMonkey,
    If you look at the contents of a typical runSimulation command line, you will immediately observe why running it from a different directory results in the errors you report. For example, one of my runSImulation command line files is shown below:
    /tools/bin/spectre input.scs +escchars +log ../psf/spectre.out -format psfxl
    -raw ../psf +aps +mt=lsf +lqtimeout 0 -maxw 5 -maxn 5 -env ade +lorder
    MMSIM:PRODUCT +dcopt +disk_check=100e9 -ahdllibdir
    <path to ahdllibdir>/input.ahdlSimDB +logstatus
    The file has relative paths for the input.scs file, output spectre.out file, and psf directory. You might use a shell variable to include as an argument to runSImulation such that the syntax is:
    runSimulation <path to results directory>
    where the "results" directory has the two subdirectories "psf" and netlist"
    and modify the command line to something like:
    /tools/bin/spectre $1/netlist/input.scs +escchars +log $1/psf/spectre.out -format psfxl
    -raw $1/psf +aps +mt=lsf +lqtimeout 0 -maxw 5 -maxn 5 -env ade +lorder
    You might add these few lines as a reminder of the command syntax:
    f [ $# -ne 1 ]; then
       echo "Usage: runSimulation  <path to results directory>"
       exit 127
    fi
    Shawn
    First of all, this is not really a supported flow - the runSimulation script is a means to an end in the simulation flow, and it's not really there for you to run batch simulations afterwards. If you want to run AMS simulations (this is a mixed-signal simulation, not a spectre simulation, so the flow is more complex than Shawn was describing, which is for spectre) from batch, the runams utility is a far better way of achieving that. This can then generate the netlist and run the simulation as needed.
    If however you really want to run the runSimulation script (either for AMS or for Spectre) without following the expected flow of running it from the netlist directory (which is what ADE does), then by far the simplest modification is to add
    cd /path/to/the/netlist/directory
    at the beginning of the runSimulation script (well, after the shebang line). Then you don't have to touch anything else in the script. With AMS it wouldn't be as simple as just editing the command as Shawn suggested - there are other files that would have needed changing too, such as xrunArgs, and you couldn't put $1 in those. So simply changing the working directory at the beginning of the script is by far the simplest modification.
  • SpiceMonkey
    SpiceMonkey over 3 years ago in reply to Andrew Beckett
    Thank you, I use runSimulation script because this is recommended AMS-Simulink co-simulation flow from USER Manual. Then I can run co-simulation without start cadence GUI. cd to the netlist directory is indeed the easiest way.
  • SpiceMonkey
    SpiceMonkey over 3 years ago in reply to ShawnLogan
    Thank you for your reply, actually I tried to modify the paths inside the script, as Andrew said, there are too many...
